does the discount code work for Fluke Gear? If so, can someone pm the updated code.. Thanks.
PM sent to maginnovision, zorkmids, jjoonathan, and Hamster.
I also just retired, & am repopulating my test bench that I used back when I worked at a TV-repair shop (remember those ??). Might I please get access to the discount code for TEquipment ?
Many thanks,
gfkdrobi
Please read the first post in the thread.
Could someone PM me the code if they have it!
Long time lurker and would like to purchase a rigol. Please pm code if still available. Thank you!
Code please
Sent from my SAMSUNG-SM-G891A using Tapatalk
Also a code for me, please.
Pls read the first post. Something should click.
Long time lurker looking to purchase a Rigol DP832.
Read the first post
- could you send the TEquipment discount code when you have a minute?
Thank you!
p
I'm not sure I qualify, but if I do, could I get the discount code please?
As detailed in another post, I'm ready to pull the trigger and the target is a DS1054Z Kit at TEquipment.
Could someone please pass along the code?
thanks!
thanks!
Please read the first post.
I did read the first post...
I've also spent all my waking hours for the last three days reading virtually every post/thread I could find on the scopes I was interested in before deciding on my buy...
Hope that helps.
thanks.
Has the discount code changed?
Also, where do you even enter it in at anymore?
It's time to buy a pre-heater and Omni-Vises!
I did read the first post... I've also spent all my waking hours for the last three days reading virtually every post/thread I could find on the scopes I was interested in before deciding on my buy...
Hope that helps.
thanks.
Sadly, it doesn't. And as you've read the first post, you should understand why.
The good news is it doesn't take much to qualify. In fact it's quite possible to achieve it in a single post and has been done in a number of cases (the
New Member Please Introduce Yourself thread is a good starting point for this).
Yes it has.
PM sent.
got an order pending. can you pm me the code please. thanks.
May I have the discount code please?
PM sent.
The good news is it doesn't take much to qualify. In fact it's quite possible to achieve it in a single post and has been done in a number of cases (the New Member Please Introduce Yourself thread is a good starting point for this).
Age must have dimmed my analytic abilities since I must be missing something....
PM sent. Please read its entirety.
