Author Topic: EMC probe use  (Read 2236 times)
Offline GrandchuckTopic starter
EMC probe use
« on: March 06, 2023, 04:49:29 pm »
These are inexpensive but seem useful:  https://www.ebay.com/itm/334526399735
The picture below shows them applied to a power module.  The module conditions:
Input 8 vdc @ 0.36A
Output 12 vdc @ 0.2A
E probe channel 1
H probe channel 2
Seems that using EMC probes might also be useful when designing and/or troubleshooting.  Does anybody here do that?
Online nctnico
Re: EMC probe use
« Reply #1 on: March 06, 2023, 09:47:38 pm »
These kind of probes are useful indeed to find sources of certain frequency bands on a PCB. They should be in everyone's toolbox who is dealing with EMC problems.
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
Re: EMC probe use
« Reply #2 on: March 06, 2023, 11:07:12 pm »
Yes :)  I actually made an introductory video on the topic
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: MarkL, alm, Detlev
Offline pope
  • Country: pt
Re: EMC probe use
« Reply #3 on: March 07, 2023, 08:59:50 am »
These seem to be out of stock everywhere (ebay, amazon, aliexpress).
Do you have any other source that can be purchased from?
Offline oddbits
Re: EMC probe use
« Reply #4 on: March 07, 2023, 10:31:21 am »
Loads on ebay china sellers , for as little as £9 with free postage , just ordered a set ..
Hope links are ok ?.
« Last Edit: March 07, 2023, 10:33:53 am by oddbits »
Offline Xandinator
Re: EMC probe use
« Reply #5 on: March 21, 2023, 02:05:55 am »
If you want to go cheap, you can even build them yourself, Dave put up a video:
Offline jonpaul
  • Analog, magnetics, Pwr high voltage, Audio, Cinema
    • IEEE Spectrum
Re: EMC probe use
« Reply #6 on: March 22, 2023, 01:07:26 pm »
zero cost probe
1m RG174/U, wind 10t in 10..25 mm dia coil.
Terminate centers  to BNC conn
Shield is connected at one end only to BNC rtn
Finished with insulation dip, tape or similar
Jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
Re: EMC probe use
« Reply #7 on: March 22, 2023, 04:11:09 pm »
Here is a nearly zero cost E probe.  It is shown compared to the one in the assortment that I recently bought .  It has been insulated since the photo was taken.  It outperforms the one at the top by a wide margin ... much less unwanted 60 Hz noise susceptibility.
