My memory dump is attached.
FYI, my unit is running the latest A.14.06 firmware.
In binary format.
This Andrews's dump is a dump of ESALOADR (size 0xB5B48 bytes). Not ESAFW.
what if we powered up normally. once up and firmware loaded we insert the ESALOADER disc and reset
DRAM should still be loaded.
we can then break into monitor and try to dump memory?
That is a nice idea. Please try it.
Ctrl+C is also the Break key, you can try that.
Not working.
What BootRom Version are you on
Mine is E4401 Bootrom, 5.00
Just to be sure we're all on same Page
This is the Debug menu and not what we need
----- System/pSOS Debug commands: -----
'?' - this help message.
'j' - drop into breakpoint.
'^C' - Abort to monitor.
'^P' - Process status info, and LOTS of it.
'[dD]' - Print DLP debug information.
'[bB]' - Big memory hog report.
'[pP]' - Process ONLY status info.
'[eE]' - Exchange info.
'[gG]' - toggle breakpoint exception handlers on/off
'[tT]' - Time log.
'[hH]' - History log.
'[oO]' - Memory segment ownership.
'[mM]' - Memory segment summary.
'[sS]' - Semaphore ownership, etc.
'[uU]' - maximum process stack Usage.
'[vV]' - memory Validity check.
'[iI]' - Show psosSystemData.
'[1]' - Show NVRAM contents.
'[wW] <process name>' - Show process stack trace.
This is the Monitor Menu and what we're after.
bc [<hex boot config>] - set the bootrom configuration (see bchelp)
bootvars- display bootrom variables
bs - force a breakpoint when starting
dbyte [<hex start address> [num bytes]] - display memory using bytes
dlong [<hex start address> [num bytes]] - display memory using longs
dmem [<hex start address> [num bytes]] - display memory using bytes
dword [<hex start address> [num bytes]] - display memory using words
gbreak - force a gdb breakpoint
gdb - enable gdb trapping of exceptions
gu [<hex start addr>] - go to start address
hmon [device] - download into memory
rty test routine
sbyte <hex start address> <hexchars> - set memory using bytes
slong <hex start address> <hexchars> - set memory using longs
smem <hex start address> <hexchars> - set memory using bytes
sword <hex start address> <hexchars> - set memory using words
version - display bootrom version
Please dump from 0x0400 0000 to 0x0401 1000. Just to check if this is BOOTROM-related.
I think this can be done with ESALOADR. No need for ESAFW.
How do you trigger DEBUG MENU?
For information:
DEBUG MENU is inside ESALOADR
MONITOR MENU is inside BOOTROM (called from within DEBUG MENU via ^C)
Using this procedure:
- Boot from ESALOADR floppy, drop into ROM monitor menu (j, CTRL+C)
- Retry test routine ('rty')
- Test routine will fail/hang, then remove floppy and power cycle the unit
- Boot from flash will fail and drop you back into ROM monitor
My memory dump (0x04011000-0x04900000) looks nearly identical to the concatenated ESAFW file that Sandra shared earlier with only a handful of addresses differing, and differs quite a lot from the ESALOADR.
I believe this dump is the ESAFW from flash. On the second boot (step 4 of my procedure), the ESALOADR disk is not present so the unit must load from flash.
when you boot normally the Debug Menu "----- System/pSOS Debug commands: ----- " is always there.
when you boot from the ESALOADER you don't initially see a menu. Pressing ? when show same menu above, you can CTRL+C and it causes an exception then you're in the Monitor menu where you can dump memory
I've hooked up a reset switch, booted normally, entered AXZ for the opt and 0123456789ABC for the code.
inserted the ESALOADER, and hit reset.
once rebooted I got into the mornitor and did 2 dumps (ones still dumping)
first is will be
second will be
0x0401 1000 to 0x0490 0000
soon as done i'll edit and post to this message
My HostID is 29611027
My BootRom is V5.00
This dump is exactly Sandra's ESAFW with 8 bytes different (in the middle of the code
The problem is that you didn't run the app before taking the dump. We need the dump
after the app has run/is running. Because all the rest of the mem is 0x00s.
It MUST be possible to abort into Monitor mode from within ESAFW because ESAFW also has the DEBUG MENU in the code (with the ^C option). Just saw that in the code.
This dump is exactly Sandra's ESAFW with 8 bytes different (in the middle of the code ).
The problem is that you didn't run the app before taking the dump. We need the dump after the app has run/is running. Because all the rest of the mem is 0x00s.
Got it, didn't quite grasp what the issue was before. The application was definitely not running when I created the new dump.
Looking forward to seeing Sandra's results
When I boot from the ESALOADER and see the Menu ^C works fine
when I boot normally and see the Menu, even though ^C is in the menu all I see is a message that it doesn't recognize the keypress
Ohhh. That's another story. Let's wait for your dumps. I've got my fingers crossed.
If not successfull, I'll ask you to do me a log dump of all the submenu options of the DEBUG MENU (just the 1st screen) so that I can crosscheck the functions.
still dumping, it's up to 0x040Dxxxx and it's all zero's in this area
i'm trying to figure our device addressing
the max address is 0x07FFFFFF only ADDRESS BIT 0..27 are used
21,22,23 are used to address the FLASH memory (thru a 74138)
U55 controls the addressing which is the communications controller which goes to the enable pin on the 74138
What is the specific msg?
I saw somewhere that the app and mem would not go upper that 0x06000000. Maybe in your boot logs...
That doesn't mean that physically it couldn't go to that limit mentioned by you.
From the hardware side it's physically limited to 0x07FFFFFF (A0..A27) the remaining bits are NC
Unknown debug char: 'C' (0x43). Press '?' for help.
if I do CTRL+C its
Unknown debug char: ' ' (0x03). Press '?' for help. (i think) still dumping so I can't check
I do not miss dialup speeds
There are no sub menus
each option is a direct action in the menus
the may take parms but that is passed with the option you want
Is anyone able when booting normally (no ESALOADER Disc) able to do the CTRL+C and enter the Monitor Program?
Sure, all I want is a dump of the 1st page of those direct actions (just to identify the strings in it).
You don't need to try other keys. The DEBUG in ESAFW doesn't have the code for "^C". So we would need to patch it.
BTW, the DEBUG MENUs of ESAFW and ESALOADR have slight differences. I think ESAFW has more options.
I do have some spare FLASH memory for the BootLoader so if a patch isnt to hard maybe thats the way to go???
These are the menu options seen when booting
This is the Debug menu when booting Normally, you have to do a ? to see it----- System/pSOS Debug commands: -----
'[tT]' - Time log.
This is the Monitor Menu from when using ESALOADER.bc [<hex boot config>] - set the bootrom configuration (see bchelp)
rty test routine
I tried but it did not work.
I didn't get FDD todayso I still have older firmware.
that was these then
No, maybe I explained wrong:
I want the next steps in each of those options (just DEBUG MENU).
that was these then
if I type a option it executes the command so if thats what you want heres some
is this what you're after?
***** Mosquito Bootrom *****
Copyright 1988-1997,
Hewlett-Packard Company, all rights reserved.
@(#)HEWLETT-PACKARD, E4401 Bootrom, 5.00
@(#)LDS Rev: 3.02 - Module Incremental (Sep 9 2003)
@(#)Linked: Sep 9 2003 14:46:44
Bootrom Checksum ...
Bootrom DRAM: Testing 69632 bytes at 0x04000000
Non Destructive SRAM Test ...
Main Firmware DRAM: Testing 33484800 bytes at 0x04011000
Main FW Checksum ...
Self-tests complete.SRAM selftest results:
Start = 0xa000000
End = 0xa007fa3
Errors = 0x0
DRAM selftest results:
Start = 0x4011000
End = 0x6000000
Errors = 0x0
hpibPort = 0x8005000
hpibPort = 0x8005000, bus Address = 19
Cache Enabled
16MBytes of FLASH
Download to Flash Selected
>>> mainMain()
text segment: 0x4011000 thru 0x4435e14 ( 424e14 bytes)
data segment: 0x4600000 thru 0x476dd88 ( 16dd88 bytes)
bss segment: 0x476dd88 thru 0x48bcce8 ( 14ef60 bytes)
ROM size: 0x00592b9c ( 592b9c bytes of 4194304 max.)
memory pool (all): 0x048bcce8 thru 0x05ffffff (24392472 bytes)
Calling start_psos() ...
>>>> debug() process starting
DLP Loaded - Power Suite Utilities, A.06.05, Nov 21 2003 15:45:40
'[tT]' - Time log.
'[9]' - Show Exception Report.
>d
DLP LIST
Name State Text Data BSS
c:dlp\ps2\ps2.o Loaded 0x5c3dcc8/1751472 0x5c3bcb4/8192 0x5b6abe0/856256
c:dlp\pn\pn.o Unlicensed 0x0/0 0x0/0 0x0/0
c:dlp\catv\catv.o Unlicensed 0x0/0 0x0/0 0x0/0
Currently 1 DLP's loaded
>b
Memory HOG report - oink oink
caller PC count bytes
0x04338902 17072 5349060
0x04361be2 1 1751492
0x00000000 111 1049872
0x04361bfe 1 856276
0x05d00d06 194 798504
0x05d01948 83 341628
0x043ebcfe 83 294836
0x05cefb16 61 245220
0x05cf28b6 40 160800
0x05ceceb2 33 132660
0x05cf564a 15 60300
0x043eb0f0 339 39892
0x042b66a2 1 32792
0x05cea37a 7 28140
0x04345af2 53 26632
0x05d0235c 3 12348
0x042def9e 1 11108
0x04361bf0 1 8212
0x042ec426 1 2596
0x042ec3e2 1 2148
0x0412a3d0 1 2068
0x042ec404 1 1196
0x04364636 1 1032
0x042ec3c0 1 1028
0x042def8c 1 812
0x0414b2a2 3 624
0x0a0008f6 1 532
0x0a000446 1 532
0x0a0005ea 1 532
0x0a000626 1 84
>p
pid PNAME STAT/M PRI GID POS TIX MEMORY STK CPU
0x048ca38c SWFI RUN 51 0 * 1 0kB 8% 25%
0x048cc0f0 AAFI RDY 51 0 1 1 0kB 12% 0%
0x048c9714 IDLE RDY 0 0 2 1 0kB 6% 8%
0x048ccf30 CLOK paus 100 0 . 0 0kB 16% 0%
0x048c9ffc DIst paus 52 0 . 3106 0kB 3% 0%
0x048c9aa4 DRST paus 80 0 . 61 0kB 47% 0%
0x048c99c0 FMOT paus 100 0 . 43 0kB 47% 0%
0x048cd014 UPDT xblk 249 0 . 1 0kB 23% 0%
0x048cce4c MAXM xblk 60 0 . 1 0kB 6% 0%
0x048ccc84 LLMR xblk 60 0 . 1 0kB 6% 0%
0x048ccba0 PRNT xblk 60 0 . 1 0kB 8% 0%
0x048ccabc DSPF xblk 51 0 . 1 0kB 5% 0%
0x048cc9d8 DSPM xblk 60 0 . 1 0kB 6% 0%
0x048cc8f4 DMFI xblk 51 0 . 1 0kB 5% 0%
0x048cc810 DMMR xblk 60 0 . 1 0kB 6% 0%
0x048cc648 FCFI xblk 51 0 . 1 0kB 5% 0%
0x048cc564 FCMR xblk 60 0 . 1 0kB 6% 0%
0x048cc480 ANSQ xblk 52 0 . 1 0kB 13% 0%
0x048cc39c ANFI xblk 51 0 . 1 0kB 13% 0%
0x048cc2b8 ANMR xblk 60 0 . 1 0kB 6% 0%
0x048cc1d4 AASQ xblk 52 0 . 1 0kB 21% 28%
0x048cc00c AAMR xblk 60 0 . 1 0kB 6% 0%
0x048cbf28 SYMR xblk 60 0 . 1 0kB 8% 0%
0x048cbe44 SGMR xblk 60 0 . 1 0kB 6% 0%
0x048cbd60 ZMKR xblk 60 0 . 1 0kB 6% 0%
0x048cbc7c MKR xblk 60 0 . 1 0kB 6% 0%
0x048cbb98 DEF3 xblk 51 0 . 1 0kB 5% 0%
0x048cbab4 SNFI xblk 51 0 . 1 0kB 5% 0%
0x048cb9d0 SNMR xblk 60 0 . 1 0kB 6% 0%
0x048cb8ec DEF2 xblk 51 0 . 1 0kB 5% 0%
0x048cb808 LGDT xblk 251 0 . 1 0kB 8% 0%
0x048cb724 LGDE xblk 60 0 . 1 0kB 6% 0%
0x048cb640 DSFI xblk 51 0 . 1 0kB 5% 0%
0x048cb55c LGDT xblk 251 0 . 1 0kB 8% 0%
0x048cb478 LGDS xblk 60 0 . 1 0kB 6% 0%
0x048cb394 SWFI xblk 51 0 . 1 0kB 5% 0%
0x048cb2b0 LGST xblk 251 0 . 1 0kB 8% 0%
0x048cb1cc LGSW xblk 60 0 . 1 0kB 6% 0%
0x048cb0e8 DEFI xblk 51 0 . 1 0kB 5% 0%
0x048cb004 DEMT xblk 251 0 . 1 0kB 8% 0%
0x048caf20 DEMR xblk 60 0 . 1 0kB 6% 0%
0x048cae3c DMZF xblk 51 0 . 1 0kB 5% 0%
0x048cad58 ZDMT xblk 251 0 . 1 0kB 8% 0%
0x048cac74 ZDMR xblk 60 0 . 1 0kB 6% 0%
0x048cab90 SIFI xblk 51 0 . 1 0kB 5% 0%
0x048caaac SIMT xblk 251 0 . 1 0kB 8% 0%
0x048ca9c8 SIMR xblk 60 0 . 1 0kB 6% 0%
0x048ca8e4 DZFI xblk 51 0 . 1 0kB 5% 0%
0x048ca800 DZMT xblk 251 0 . 1 0kB 8% 0%
0x048ca71c DZMR xblk 60 0 . 1 0kB 6% 0%
0x048ca638 DSFI xblk 51 0 . 1 0kB 5% 0%
0x048ca554 DSMT xblk 251 0 . 1 0kB 8% 0%
0x048ca470 DSMR xblk 60 0 . 1 0kB 6% 0%
0x048ca2a8 SWMT xblk 251 0 . 1 0kB 8% 0%
0x048ca1c4 SWMR xblk 60 0 . 1 0kB 6% 1%
0x048ca0e0 MIME xblk 79 0 . 1 0kB 6% 2%
0x048c9f18 FPLP xblk 250 0 . 1 0kB 9% 0%
0x048c9e34 DCAS xblk 251 0 . 1 0kB 8% 0%
0x048c9d50 RLCN xblk 230 0 . 1 0kB 8% 0%
0x048c9c6c REMT xblk 250 0 . 1 0kB 5% 0%
0x048c9b88 PCKB xblk 230 0 . 1 0kB 8% 0%
0x048c97f8 DISP xblk 253 0 . 1 0kB 8% 4%
0x048c98dc APPS xblk 230 0 . 1 0kB 25% 0%
0x048c9630 ROOT xblk 230 0 . 1 0kB 4% 32%
>> EVENTS: W(0x0) S(0x2000)
64 Process(s) (27 avail); Total time: 4569 ticks.
>e
xid XNAME TYPE ACC maxQ Qlen BLOCKED
0x048c1584 fifo any 1 0 REMT
0x048c1562 UPDI fifo any 1 0 UPDT
0x048c1540 MAXM fifo any inf 0 MAXM
0x048c151e Sign fifo any inf 0
0x048c14fc LIMI fifo any inf 0 LLMR
0x048c14da DSPM fifo any inf 0 DSPM
0x048c14b8 DSPS fifo any 1 0
0x048c1496 DSPF fifo any inf 0 DSPF
0x048c1474 SPEC fifo any 1 0
0x048c1452 SPEC fifo any 1 0
0x048c1430 DMMR fifo any inf 0 DMMR
0x048c140e DMFI fifo any inf 0 DMFI
0x048c13ec SPEC fifo any 1 0
0x048c13ca FCMR fifo any inf 0 FCMR
0x048c13a8 FCFI fifo any inf 0 FCFI
0x048c1386 SPEC fifo any 1 0
0x048c1364 ANSQ fifo any inf 0 ANSQ
0x048c1342 ANFI fifo any inf 0 ANFI
0x048c1320 ANFS fifo any inf 0
0x048c12fe ANOW fifo any 20 0
0x048c12dc ANMR fifo any inf 0 ANMR
0x048c12ba SPEC fifo any 1 0
0x048c1298 AARS fifo any 1 0 AASQ
0x048c1276 AAFI fifo any inf 0
0x048c1254 AAFS fifo any inf 0
0x048c1232 AAMR fifo any inf 0 AAMR
0x048c1210 SPEC fifo any 1 0
0x048c11ee CMR fifo any inf 0
0x048c11cc SPEC fifo any 1 0
0x048c11aa SIGT fifo any inf 0 SGMR
0x048c1188 ZMKM fifo any inf 0 ZMKR
0x048c1166 MKMR fifo any inf 0 MKR
0x048c1144 DEF3 fifo any inf 0 DEF3
0x048c1122 SNFI fifo any inf 0 SNFI
0x048c1100 SNMR fifo any inf 0 SNMR
0x048c10de SPEC fifo any 1 0
0x048c10bc DEF2 fifo any inf 0 DEF2
0x048c109a LGDT fifo any 1 0 LGDT
0x048c1078 LGDE fifo any inf 0 LGDE
0x048c1056 SPEC fifo any 1 0
0x048c1034 DSFI fifo any inf 0 DSFI
0x048c1012 LGDT fifo any 1 0 LGDT
0x048c0ff0 LGDS fifo any inf 0 LGDS
0x048c0fce SPEC fifo any 1 0
0x048c0fac SWFI fifo any inf 0 SWFI
0x048c0f8a LGST fifo any 1 0 LGST
0x048c0f68 LGSW fifo any inf 0 LGSW
0x048c0f46 SPEC fifo any 1 0
0x048c0f24 DEFI fifo any inf 0 DEFI
0x048c0f02 DEMT fifo any 1 0 DEMT
0x048c0ee0 DEMR fifo any inf 0 DEMR
0x048c0ebe SPEC fifo any 1 0
0x048c0e9c DMZF fifo any inf 0 DMZF
0x048c0e7a ZDMT fifo any 1 0 ZDMT
0x048c0e58 ZDMR fifo any inf 0 ZDMR
0x048c0e36 SPEC fifo any 1 0
0x048c0e14 SIFI fifo any inf 0 SIFI
0x048c0df2 SIMT fifo any 1 0 SIMT
0x048c0dd0 SIMR fifo any inf 0 SIMR
0x048c0dae SPEC fifo any 1 0
0x048c0d8c DZFI fifo any inf 0 DZFI
0x048c0d6a DZMT fifo any 1 0 DZMT
0x048c0d48 DZMR fifo any inf 0 DZMR
0x048c0d26 SPEC fifo any 1 0
0x048c0d04 DSFI fifo any inf 0 DSFI
0x048c0ce2 DSMT fifo any 1 0 DSMT
0x048c0cc0 DSMR fifo any inf 0 DSMR
0x048c0c9e SPEC fifo any 1 0
0x048c0c7c SWFI fifo any inf 0
0x048c0c5a SWMT fifo any 1 0 SWMT
0x048c0c38 SWMR fifo any inf 0 SWMR
0x048c0c16 SPEC fifo any 1 0
0x048c0bf4 shrL fifo any 1 0
0x048c0bd2 ACTV fifo any 1 0
0x048c0bb0 hihr fifo any 1 0
0x048c0b8e hihr fifo any 1 0
0x048c0b6c hihr fifo any 1 0
0x048c0b4a hihr fifo any 1 0
0x048c0b28 MENU fifo any 1 0
0x048c0b06 MENU fifo any 1 0
0x048c0ae4 MENU fifo any 1 0
0x048c0ac2 MENU fifo any 1 0
0x048c0aa0 MENU fifo any 1 0
0x048c0a7e MENU fifo any 1 0
0x048c0a5c MENU fifo any 1 0
0x048c0a3a MENU fifo any 1 0
0x048c0a18 MENU fifo any 1 0
0x048c09f6 ACTV fifo any 1 0
0x048c09d4 SDRL fifo any 1 0
0x048c09b2 SDIL fifo any 1 0
0x048c0990 R2 fifo any 1 0
0x048c096e R1 fifo any 1 0
0x048c094c R0 fifo any 1 0
0x048c092a isLk fifo any 1 0
0x048c0908 dtLk fifo any 1 0
0x048c08e6 mSTM fifo any inf 0 MIME
0x048c08c4 mMIN fifo any inf 0
0x048c08a2 mMCL fifo any inf 0
0x048c0880 mMCR fifo any inf 0
0x048c085e mMDA fifo any inf 1
0x048c083c mMSA fifo any inf 0
0x048c081a mDVL fifo any inf 0
0x048c07f8 dest fifo any inf 0
0x048c07d6 mLDS fifo any inf 0
0x048c07b4 FNSL fifo any 1 0
0x048c0792 DDET fifo any inf 0
0x048c0770 DTRG fifo any inf 0
0x048c074e DSWP fifo any inf 0
0x048c072c Didi fifo any inf 0
0x048c070a cntw fifo any 1 0
0x048c06e8 cntx fifo any 1 0
0x048c06c6 dRes fifo any 1 0
0x048c06a4 Dlp fifo any 1 0
0x048c0682 CalC fifo any 1 0
0x048c0660 Scpi fifo any 1 0
0x048c063e LG1 fifo any 1 0
0x048c061c ANON fifo any 1 0
0x048c05fa GPIB fifo any 1 0
0x048c05d8 PCkb fifo any 1 0 PCKB
0x048c05b6 DISP fifo any 1 0 DISP
0x048c0594 OMMG fifo any 1 0
0x048c0572 UNS fifo any 1 0
0x048c0550 RLDS fifo any 1 0 ROOT
0x048c052e BW fifo any 1 0
0x048c050c GLds fifo any 1 0
0x048c04ea BLds fifo any inf 1
0x048c04c8 CISW fifo any 1 0
0x048c04a6 MRLK fifo any 1 0
0x048c0484 HWLK fifo any 1 0
0x048c0462 FP fifo any 1 0 FPLP
0x048c0440 ADCF fifo any 1 0
0x048c041e DIRg fifo any 1 0
0x048c03fc ANON fifo any 1 0
0x048c03da DIRf fifo any 1 0
0x048c03b8 ANON fifo any 1 0
0x048c0396 SIOB fifo any 1 0
0x048c0374 CALM fifo any 1 0
0x048c0352 DIRe fifo any 1 0
0x048c0330 ANON fifo any 1 0
0x048c030e DIRd fifo any 1 0
0x048c02ec DIRc fifo any 1 0
0x048c02ca DIRb fifo any 1 0
0x048c02a8 DIRa fifo any 1 0
0x048c0286 APPS fifo any inf 0 APPS
0x048c0264 DLLK fifo any 1 0
0x048c0242 SUBL fifo any 1 0
0x048c0220 LCSH fifo any 1 0
0x048c01fe FBUF fifo any 1 0
0x048c01dc DCAS fifo any 1 0 DCAS
0x048c01ba RLCN fifo any 1 0 RLCN
0x048c0198 MROF fifo any 1 0
0x048c0176 MRON fifo any 1 0
0x048c0154 SWSP fifo any 1 0
0x048c0132 SRQ fifo any 1 0 SYMR
0x048c0110 PRTH fifo any 1 0 PRNT
155 Exchange(s) (245 avail).
2 Msg buffer(s) (1022 avail).
>g
Breakpoint handler installed
>i
PsosSystemData (0x048bcce8):
(0x048bcce8) OS_PCB *runningPCB = 0x048ca38c
(0x048bccec) OS_PCB *readyList = 0x048c97f8
(0x048bccf0) OS_PCB *pauseList = 0x048ccf30
(0x048bccf4) OS_PCB *pcbActiveHead = 0x048cd014
(0x048bccf8) OS_PCB *pcbFreeHead = 0x048ccd68
(0x048bccfc) OS_XCB *xcbActiveHead = 0x048c1584
(0x048bcd00) OS_XCB *xcbFreeHead = 0x048c15a6
(0x048bcd04) OS_Message *mgbFreeHead = 0x048c3750
(0x048bcd08) void *sstackEnd = 0x048c0110
(0x048bcd0c) short kernelLevel = 0
(0x048bcd0e) short reserved1 = 0
(0x048bcd10) int reserved2 = 1280
(0x048bcd14) int phileData = 620765184
(0x048bcd18) int probeEntry = 71205862
(0x048bcd1c) OS_PCB *memQHead = 0x048bcd1c
(0x048bcd20) OS_PCB *memQTail = 0x048bcd1c
(0x048bcd24) int timeoutTicks = 41
(0x048bcd28) short ticks = 45
(0x048bcd2a) short pad1 = 0
(0x048bcd2c) int time = 292
(0x048bcd30) int date = 130155777
(0x048bcd34) char motbl[12] =
(0x048bcd40) short ticksPerSec = 100
(0x048bcd42) short ticksPerSlice = 1
(0x048bcd44) char todset =
(0x048bcd45) char eventRace = (0x048bcd46) char unusedPad[2] =
(0x048bcd48) Lds_UInt32 switchProc = 0
(0x048bcd4c) regionInfo[0].minSeg = 20
(0x048bcd50) regionInfo[0].maxSeg = 58796
(0x048bcd54) regionInfo[0].minPend = 6020
(0x048bcd58) regionInfo[0].regionEnd = 0x048dcce7
(0x048bcd5c) regionInfo[0].regionName = REG1
(0x048bcd60) regionInfo[0].freeHead = 0x048ce73c
(0x048bcd64) regionInfo[0].freeTail = 0x048d3e30
(0x048bcd68) regionInfo[0].regionFlags = 0
(0x048bcd6c) regionInfo[1].minSeg = 20
(0x048bcd70) regionInfo[1].maxSeg = 24261400
(0x048bcd74) regionInfo[1].minPend = 24261401
(0x048bcd78) regionInfo[1].regionEnd = 0x05ffffff
(0x048bcd78) regionInfo[1].regionEnd = 0x05Bfffff
(0x048bcd80) regionInfo[1].freeHead = 0x048dcce8
(0x048bcd84) regionInfo[1].freeTail = 0x05e74208
(0x048bcd88) regionInfo[1].regionFlags = 0
(0x048bcd8c) regionInfo[2].minSeg = 20
(0x048bcd90) regionInfo[2].maxSeg = 21844
(0x048bcd94) regionInfo[2].minPend = 21845
(0x048bcd98) regionInfo[2].regionEnd = 0x0a006393
(0x048bcd9c) regionInfo[2].regionName = dyna
(0x048bcda0) regionInfo[2].freeHead = 0x0a000e40
(0x048bcda4) regionInfo[2].freeTail = 0x0a000e40
(0x048bcda8) regionInfo[2].regionFlags = 1
(0x048bcdac) regionInfo[3].minSeg = 128
(0x048bcdb0) regionInfo[3].maxSeg = 7120
(0x048bcdb4) regionInfo[3].minPend = 7121
(0x048bcdb8) regionInfo[3].regionEnd = 0x0a007fa3
(0x048bcdbc) regionInfo[3].regionName = nvra
(0x048bcdc0) regionInfo[3].freeHead = 0x0a0063d4
(0x048bcdc4) regionInfo[3].freeTail = 0x0a0063d4
(0x048bcdc8) regionInfo[3].regionFlags = 0
(0x048bcdcc) regionInfo[4].minSeg = 0
(0x048bcdd0) regionInfo[4].maxSeg = 0
(0x048bcdd4) regionInfo[4].minPend = 0
(0x048bcdd8) regionInfo[4].regionEnd = 0x00000000
(0x048bcddc) regionInfo[4].regionName =
(0x048bcde0) regionInfo[4].freeHead = 0x00000000
(0x048bcde4) regionInfo[4].freeTail = 0x00000000
(0x048bcde8) regionInfo[4].regionFlags = 0
(0x048bcdec) regionInfo[5].minSeg = 0
(0x048bcdf0) regionInfo[5].maxSeg = 0
(0x048bcdf4) regionInfo[5].minPend = 0
(0x048bcdf8) regionInfo[5].regionEnd = 0x00000000
(0x048bcdfc) regionInfo[5].regionName =
(0x048bce00) regionInfo[5].freeHead = 0x00000000
(0x048bce04) regionInfo[5].freeTail = 0x00000000
(0x048bce08) regionInfo[5].regionFlags = 0
(0x048bce0c) regionInfo[6].minSeg = 0
(0x048bce10) regionInfo[6].maxSeg = 0
(0x048bce14) regionInfo[6].minPend = 0
(0x048bce18) regionInfo[6].regionEnd = 0x00000000
(0x048bce1c) regionInfo[6].regionName =
(0x048bce20) regionInfo[6].freeHead = 0x00000000
(0x048bce24) regionInfo[6].freeTail = 0x00000000
(0x048bce28) regionInfo[6].regionFlags = 0
(0x048bce2c) regionInfo[7].minSeg = 0
(0x048bce30) regionInfo[7].maxSeg = 0
(0x048bce34) regionInfo[7].minPend = 0
(0x048bce38) regionInfo[7].regionEnd = 0x00000000
(0x048bce3c) regionInfo[7].regionName =
(0x048bce40) regionInfo[7].freeHead = 0x00000000
(0x048bce44) regionInfo[7].freeTail = 0x00000000
(0x048bce48) regionInfo[7].regionFlags = 0
(0x048bce4c) regionInfo[8].minSeg = 0
(0x048bce50) regionInfo[8].maxSeg = 0
(0x048bce54) regionInfo[8].minPend = 0
(0x048bce58) regionInfo[8].regionEnd = 0x00000000
(0x048bce5c) regionInfo[8].regionName =
(0x048bce60) regionInfo[8].freeHead = 0x00000000
(0x048bce64) regionInfo[8].freeTail = 0x00000000
(0x048bce68) regionInfo[8].regionFlags = 0
(0x048bce6c) regionInfo[9].minSeg = 0
(0x048bce70) regionInfo[9].maxSeg = 0
(0x048bce74) regionInfo[9].minPend = 0
(0x048bce78) regionInfo[9].regionEnd = 0x00000000
(0x048bce7c) regionInfo[9].regionName =
(0x048bce80) regionInfo[9].freeHead = 0x00000000
(0x048bce84) regionInfo[9].freeTail = 0x00000000
(0x048bce88) regionInfo[9].regionFlags = 0
(0x048bce8c) regionInfo[10].minSeg = 0
(0x048bce90) regionInfo[10].maxSeg = 0
(0x048bce94) regionInfo[10].minPend = 0
(0x048bce98) regionInfo[10].regionEnd = 0x00000000
(0x048bce9c) regionInfo[10].regionName =
(0x048bcea0) regionInfo[10].freeHead = 0x00000000
(0x048bcea4) regionInfo[10].freeTail = 0x00000000
(0x048bcea8) regionInfo[10].regionFlags = 0
(0x048bceac) regionInfo[11].minSeg = 0
(0x048bceb0) regionInfo[11].maxSeg = 0
(0x048bceb4) regionInfo[11].minPend = 0
(0x048bceb8) regionInfo[11].regionEnd = 0x00000000
(0x048bcebc) regionInfo[11].regionName =
(0x048bcec0) regionInfo[11].freeHead = 0x00000000
(0x048bcec4) regionInfo[11].freeTail = 0x00000000
(0x048bcec8) regionInfo[11].regionFlags = 0
(0x048bcecc) regionInfo[12].minSeg = 0
(0x048bced0) regionInfo[12].maxSeg = 0
(0x048bced4) regionInfo[12].minPend = 0
(0x048bced8) regionInfo[12].regionEnd = 0x00000000
(0x048bcedc) regionInfo[12].regionName =
(0x048bcee0) regionInfo[12].freeHead = 0x00000000
(0x048bcee4) regionInfo[12].freeTail = 0x00000000
(0x048bcee8) regionInfo[12].regionFlags = 0
(0x048bceec) regionInfo[13].minSeg = 0
(0x048bcef0) regionInfo[13].maxSeg = 0
(0x048bcef4) regionInfo[13].minPend = 0
(0x048bcef8) regionInfo[13].regionEnd = 0x00000000
(0x048bcefc) regionInfo[13].regionName =
(0x048bcf00) regionInfo[13].freeHead = 0x00000000
(0x048bcf04) regionInfo[13].freeTail = 0x00000000
(0x048bcf08) regionInfo[13].regionFlags = 0
(0x048bcf0c) regionInfo[14].minSeg = 0
(0x048bcf10) regionInfo[14].maxSeg = 0
(0x048bcf14) regionInfo[14].minPend = 0
(0x048bcf18) regionInfo[14].regionEnd = 0x00000000
(0x048bcf1c) regionInfo[14].regionName =
(0x048bcf20) regionInfo[14].freeHead = 0x00000000
(0x048bcf24) regionInfo[14].freeTail = 0x00000000
(0x048bcf28) regionInfo[14].regionFlags = 0
(0x048bcf2c) regionInfo[15].minSeg = 0
(0x048bcf30) regionInfo[15].maxSeg = 0
(0x048bcf34) regionInfo[15].minPend = 0
(0x048bcf38) regionInfo[15].regionEnd = 0x00000000
(0x048bcf3c) regionInfo[15].regionName =
(0x048bcf40) regionInfo[15].freeHead = 0x00000000
(0x048bcf44) regionInfo[15].freeTail = 0x00000000
(0x048bcf48) regionInfo[15].regionFlags = 0
(0x048bcf4c) regionInfo[16].minSeg = 0
(0x048bcf50) regionInfo[16].maxSeg = 0
(0x048bcf54) regionInfo[16].minPend = 0
(0x048bcf58) regionInfo[16].regionEnd = 0x00000000
(0x048bcf5c) regionInfo[16].regionName =
(0x048bcf60) regionInfo[16].freeHead = 0x00000000
(0x048bcf64) regionInfo[16].freeTail = 0x00000000
(0x048bcf68) regionInfo[16].regionFlags = 0
(0x048bcf6c) regionInfo[17].minSeg = 0
(0x048bcf70) regionInfo[17].maxSeg = 0
(0x048bcf74) regionInfo[17].minPend = 0
(0x048bcf78) regionInfo[17].regionEnd = 0x00000000
(0x048bcf7c) regionInfo[17].regionName =
(0x048bcf80) regionInfo[17].freeHead = 0x00000000
(0x048bcf84) regionInfo[17].freeTail = 0x00000000
(0x048bcf88) regionInfo[17].regionFlags = 0
(0x048bcf8c) regionInfo[18].minSeg = 0
(0x048bcf90) regionInfo[18].maxSeg = 0
(0x048bcf94) regionInfo[18].minPend = 0
(0x048bcf98) regionInfo[18].regionEnd = 0x00000000
(0x048bcf9c) regionInfo[18].regionName =
(0x048bcfa0) regionInfo[18].freeHead = 0x00000000
(0x048bcfa4) regionInfo[18].freeTail = 0x00000000
(0x048bcfa8) regionInfo[18].regionFlags = 0
(0x048bcfac) regionInfo[19].minSeg = 0
(0x048bcfb0) regionInfo[19].maxSeg = 0
(0x048bcfb4) regionInfo[19].minPend = 0
(0x048bcfb8) regionInfo[19].regionEnd = 0x00000000
(0x048bcfbc) regionInfo[19].regionName =
(0x048bcfc0) regionInfo[19].freeHead = 0x00000000
(0x048bcfc4) regionInfo[19].freeTail = 0x00000000
(0x048bcfc8) regionInfo[19].regionFlags = 0
(0x048bcfcc) regionSaveInfo[0] = 0x00000000
(0x048bcfd0) regionSaveInfo[1] = 0x00000000
(0x048bcfd4) regionSaveInfo[2] = 0x0a000004
(0x048bcfd8) regionSaveInfo[3] = 0x00000000
(0x048bcfdc) regionSaveInfo[4] = 0x00000000
(0x048bcfe0) regionSaveInfo[5] = 0x00000000
(0x048bcfe4) regionSaveInfo[6] = 0x00000000
(0x048bcfe8) regionSaveInfo[7] = 0x00000000
(0x048bcfec) regionSaveInfo[8] = 0x00000000
(0x048bcff0) regionSaveInfo[9] = 0x00000000
(0x048bcff4) regionSaveInfo[10] = 0x00000000
(0x048bcff8) regionSaveInfo[11] = 0x00000000
(0x048bcffc) regionSaveInfo[12] = 0x00000000
(0x048bd000) regionSaveInfo[13] = 0x00000000
(0x048bd004) regionSaveInfo[14] = 0x00000000
(0x048bd008) regionSaveInfo[15] = 0x00000000
(0x048bd00c) regionSaveInfo[16] = 0x00000000
(0x048bd010) regionSaveInfo[17] = 0x00000000
(0x048bd014) regionSaveInfo[18] = 0x00000000
(0x048bd018) regionSaveInfo[19] = 0x00000000
9>
Contents of the Exception Report:
[0x0a007fa4] D0 = 0x00000000
[0x0a007fa8] D1 = 0x00000000
[0x0a007fac] D2 = 0x00000000
[0x0a007fb0] D3 = 0x00000000
[0x0a007fb4] D4 = 0x00000000
[0x0a007fb8] D5 = 0x00000000
[0x0a007fbc] D6 = 0x00000000
[0x0a007fc0] D7 = 0x00000000
[0x0a007fc4] A0 = 0x00000000
[0x0a007fc8] A1 = 0x00000000
[0x0a007fcc] A2 = 0x00000000
[0x0a007fd0] A3 = 0x00008000
[0x0a007fd4] A4 = 0x00000000
[0x0a007fd8] A5 = 0x00000000
[0x0a007fdc] A6 = 0x00000000
[0x0a007fe0] A7 = 0x00000000
[0x0a007fe4] SSP = 0x00000000
[0x0a007fe8] SR = 0x0000
[0x0a007fec] PC = 0x00000000
[0x0a007fec] FMT/VO = 0x0000
'[tT]' - Time log.
