Hi, I've just got a Fluke 177. The thing that I don't like about is that the backlight is way too dim. Meters under 50$ beat the display luminosity by far. As I've seen there are models out there with nice and bright white backlight. Why did they put this rubbish green backlight?
Got this one from a guy for under 200$, it was never used, the display still has the protecting film on top.
I don't know how old it is... Any way I can find out?
Replacing the LEDs seems the best solution so far. It should be pretty easy to replace as they are on the main PCB.
Maybe you can crack it open and swap the LEDs for some bright white ones.
Measure the VF over the diodes, and trying swapping for low current pure green models.
Why pure green? The human eye has the highest sensitivity on this wavelength.
Newer Flukes have the blueist white back light. I prefer the green backlight of the older models.
Thanks for the tip with the green wavelength (510 nm). I still prefer white ones, will come here with pictures after I "mod" it.
Hello, andyb2022!
Old Flukes have this green backlight which will fade over time depending on the battery voltage. Just replace it and see the difference. Newer Flukes same model have a cold white backlight which I think does not fade. By "new" or "old" I am referring to the manufacturing date.
Multumesc de raspuns! Thanks for the reply! I don't have the tools and Led's in stock right now to replace them, I'll definitely take some pics with before and after!
Many white LEDs are extremely efficient, so will still be very bright.
Bear in mind that both “pure green” and white LEDs have forward voltages much higher than traditional green LEDs (>3V, vs. 2.2V for traditional green), so it’s possible they won’t light up brightly without modifying the backlight circuit.
Looks very similar to original Fluke white backlighting, nice job!
Inline images are broken. But as attachments work fine, and that’s generally preferred as they won’t break later on, as external images often do.
