Hello,
I am currently building my small semi-pro electronics lab.
Usages:
Short-term needs:
- dc power supply repair and design
- Noise on <=100khz SMPS
- <20MHz logic (serial, little to no parallel)
- analog troubleshooting (simple stuff on furnace control boards and engine control boards)
- No to precise voltage and current measurement, ...
Long run:
- <=100Mhz logic (FPGA, 32bit MCU)
Current equipment:
- soldering stuff (hakko)
- "lab" PSU
- el cheapo Handheld multimeter
Based on that I made a basic list of the equipment I consider buying.
Oscilloscope: DS1054Z (planning on unlocking software options). The most bang for bucks as far as I know. Though I am afraid it will soon be limiting and hard on the eyes. Not sure I need 4 channels and there is a lot of good options in the €500-2k 2ch range.
I’d really like to get a good brand (Keysight, Lecroy, R&S) if I can fit an appropriate model in my budget.
Signal generator: Rigol DG1022 (non-A) €300
Seems more than good enough for my needs (100s khz square). Maybe other brands have cheaper/better options for this price?
DMM:
Main use on digital circuit. Might get used on high power circuits (main, 3ph), not quite sure whether a €50 or €100 meter is good enough in terms of input protection.
I have budgeted about €200 in test leads and accessories.
From this base I have about €900 to improve whatever is worth it. (a bit more if necessary).
Obviously not paying VAT and considering an rebate.
Any ideas/advices ? Questions I should ask myself before buying the stuff?
Thanks !
