I'm having a lot of trouble understanding the differences between a turbine and diaphragm hot air station. I know that there is something in pressure differences between the two, and a turbine can put out a higher cfm than a diaphragm hot air station, but I don't know how the two correlate with each other.
Basically, how do these two systems work? What are the pros and cons of each? Why would I even need such a high cfm from a turbine station?
