Hi there,
As promised in yesterday's EX420 thread, here is a teardown of my Extech EX430.
I posted full resolution images on imgur because of the 2MB limitation here:
http://imgur.com/a/TcEpBSorry about the quality of the pictures, it is my first public teardown and I don't have a proper lightbox.
Like I said, it's not that ugly, but the soldering quality is mediocre, through-hole resistors hand-soldered on the surface, a lot of flux residue, dubious components like those "Chang" capacitors, "Golden Power" battery. Fuses look like HRC but no brand name. Notice how they tainted one of the LCD contacts with solder. About the design itself, even if it's UL listed, I don't see a lot of input protection, there is one MOV on the small board, a PTC in the corner and that's it.
Beware if you want to remove the LCD, the anisotropic rubber is somehow glued to the PCB. I took a risk by removing it, but it still worked with the pressure of the plastic bezel when I put everyting back.
Functionally it's not such a bad meter. The measurements are spot-on with respect to my Fluke 87III. The digits are big and easy to read. The back-light is not great but usable. Probe cables are not very flexible, but the tips are very sharp. Continuity test is fast but not latched. External K-type thermocouple support is handy, that's the main reason I keep this meter. The most annoying thing is the squeaking beep sound every time you do anything. It wakes up the whole house and annoys me like hell.
