Author Topic: Fake BT138X-600D or NOT ? That is the question.  (Read 3620 times)
Offline JacquesBBBTopic starter
« on: February 25, 2015, 09:56:39 am »
Dear All,
As the BT138X-600D  triacs from NXP were only available at Mouser by thousands, I ordered some on aliexpress.
I received them, but their package seems to be of very low quality compared to the other triacs I have
of similar values from NXP (see the attached pictures).
I highly suspect that they are fake. What do you think ?
If some one has an thrustful BT138X-600D, can he post a  picture of it for comparison.
Thanks
« Last Edit: February 25, 2015, 10:06:40 am by JacquesBBB »
Offline Zucca
  • EE meid in Itali
Re: Fake BT138X-600D or NOT ? That is the question.
« Reply #1 on: February 25, 2015, 10:19:03 am »
DonĀ“t know... but.. Did you compare them just with your eyes? May be a test circuit could help you to understand if you can use them as replacement or not.
« Last Edit: February 25, 2015, 11:28:09 am by zucca »
Offline Guni
« Reply #3 on: February 25, 2015, 01:18:15 pm »
https://octopart.com/bt138x-600f-nxp+semiconductors-360503
In fact  this is more
https://octopart.com/search?q=BT138X-600D
Yes, up to now, I just compared with the eyes. The difference with the other NXP triacs was so flagrant that I did not  even made an experiment, which I may do later on if this is the only way, but this needs some time and a proper setting to test
the component at full load.
I have send a message to the supplier who says that the parts are genuine.
I send also a message to NXP  with no answer up to now.
The  pins of the  triac are of  glossy metal that looks very flimsy for a 12A  triac.
The overall quality of fabrication  is very poor : printing is not even; plastic is not well pressed.
This is why I ask on the forum, hoping that someone will have a genuine part to compare.
« Reply #4 on: March 06, 2015, 10:22:40 am »
For information, this is the message I received from NXP
From the picture, it is high possibility counterfeit part. While I would suggest you to purchase from authorized channel.
Offline McBryce
« Reply #5 on: March 06, 2015, 12:03:47 pm »
Compare the package and pin dimensions with the dimensions in the NXP Datasheet. Even looking at the picture, I'd say they don't match.
http://www.nxp.com/documents/data_sheet/BT138X-600.pdf
McBryce.
