I also got one. Feeltech FY2200S (10MHz)
but i have a problem with the offset voltage. See measurements below. Can someone please check if they have the same offset issue?
Set Measured
0.0 0.001
0.1 0.209
0.2 0.314
-0.1 0.045 (positive? must be negative)
-0.2 -0.059
By the way, the signals are made with 8 datalines from a FPGA (altera max II) these digital lines are fed to a R2R network..
There are some adjustment potmeters inside. found the ofset one and the anplitude one. but there is one more..
Thanks,
peter.
