Author Topic: Ferrex ANS-24-146 (Aldi)  (Read 2939 times)
Offline Aldo22Topic starter
« on: September 08, 2025, 11:57:06 am »
Today, I bought a DMM at Aldi while passing by.
Ferrex ANS-24-146 for CHF 7.95 (8.50 €)
It is my cheapest DMM so far, but also my only meter that has an ampere range and a GS certification.
https://www.certipedia.com/certificates/50639471?locale=en
It comes with two test leads, 2 x AAA batteries, two 600V ceramic fuses, and a manual.
It has a 3-year warranty.
All of this somewhat contradicts the impression of quality. It all looks as cheap as it is.
The accuracy is... well, it's 2000 counts.
Initial tests show:
DC and AC voltage measurements are acceptable.
Current measurements are a little off, but within specifications. Resistance measurements too.
The continuity tester is OK.
Pros:
It has auto range and manual range selection.
There is a “Rel” function.
There is a “Hold” function.
It has Min/Max and even Max-Min!
There is a 1kHz square wave signal.
It has A, mA, and uA ranges.
The display is easy to read.
It has a Cal switch inside, but I don't know how it works yet.
The banana jack spacing is correct. ;-)
Cons:
No backlight
mA on the volt jack.
Poor quality impression.
What to make of it?
Useable, partially surprising. Certainly not a bad thing to have in the trunk.
But despite the certificate and the 600V fuses, it does not inspire much confidence.
The following users thanked this post: norbert.kiszka
Offline Kean
    • Kean Electronics
Re: Ferrex ANS-24-146 (Aldi)
« Reply #1 on: September 08, 2025, 12:47:19 pm »
Amazing that they spent money (even if just a few cents) on a switch for cal mode when a couple of test pads would surely have sufficed.
The following users thanked this post: ipman, Aldo22
« Reply #2 on: September 08, 2025, 02:28:27 pm »
That's what I thought too. There are a few unusual decisions with this product.
« Reply #3 on: September 10, 2025, 12:41:52 pm »
I bought two more to play around with and for spare parts.
Today they were on sale. Now only 5.99 each.  :palm:
You probably can't even get the two 30mm 600V 10A and 250mA ceramic fuses for that price in retail stores.
I messed up the voltage calibration on my first one because I didn't know the procedure.
Maybe I can fix it later. There's a video on how to do it in the Eprom.
« Last Edit: September 10, 2025, 12:47:19 pm by Aldo22 »
« Reply #4 on: October 02, 2025, 02:38:57 pm »
After completely messing up my Ferrex with the “CAL” switch (I don't know the correct procedure), I tried to readjust it.
I had never done this with a USB programmer before and thought that a cheap Ferrex would be an ideal practice object.
And yes, it worked. I was able to correct V, Ω, μA, mA, and A.
The accuracy now seems better to me than the factory setting, especially for current measurement.
I think this cheap meter is now accurate enough for simple tasks.  :-+
IMSProg.png: The yellow markings are relevant. In reading direction: V, Ω, μA, mA, A
VDC_VAC_Ohm.jpg: 1.234VDC, 1VAC, 1kΩ
uA_mA_A.jpg: 100μA, 1mA, 1.5A
« Last Edit: October 02, 2025, 02:44:14 pm by Aldo22 »
Offline IC_Toaster
« Reply #5 on: December 18, 2025, 09:38:11 pm »
When you are going to modify a memory, it is a good idea to do a back up of the current content. In that case you can restore the original information.
I didn't know this multimeter, and now I am tempted to buy a second hand one I have found.
« Reply #6 on: December 18, 2025, 10:10:31 pm »
Or you could buy a new one.
Apparently, they are available in Spain (a few euros more expensive than here).
https://www.aldi.es/ofertas/desde-20-diciembre/multimetro-digital-1202-0-0.article.html
But don't get me wrong, it's not a really good DMM, but for this price, it has some remarkable features.
« Last Edit: December 18, 2025, 10:13:35 pm by Aldo22 »
The following users thanked this post: ipman, IC_Toaster
Offline IC_Toaster
« Reply #7 on: December 18, 2025, 10:31:12 pm »
Thank you. As you bought the multimeter on September, I thought I lost the oportunity. I was wrong on my asumption the selling dates would be similar in different countries.
I will try to buy it next Sunday.
