Author Topic: First Scope  (Read 3817 times)
Offline JohnSLTopic starter
First Scope
« on: September 15, 2014, 03:04:27 am »
I'm just getting ready to buy my first scope, and I wanted to see what people thought before I actually place the order. Right now I'm thinking of buying a Rigol DS1074Z. From what I've ready, this sounds like a good balance between low price and features. The only need I've had so far is with relatively low-frequency signals. I'm not sure what I'll be needing it for in the future, but I expect it will be signals generally below 1 MHz.
So, is this a good starter scope? Or is there another scope you would recommend? I had originally thought of buying a Rigol DS1102E, but I liked the larger screen and features of the DS1074Z.
Thanks,
  -- John
Offline marmad
  • Country: aq
    • DaysAlive
Re: First Scope
« Reply #1 on: September 15, 2014, 03:19:02 am »
Thanks,
  -- John
Definitely a good starter scope, John - and one that is future-proofed for awhile. You don't want to buy the older DS1000E series - it's not just the display size that's smaller, but they're also lacking intensity grading, high waveform update rates at fast time bases, bus decoding options, and larger memory (for better sample rates at slow time bases).
Mark
« Last Edit: September 15, 2014, 03:20:33 am by marmad »
Offline Fsck
  • sleep deprived
Re: First Scope
« Reply #2 on: September 15, 2014, 03:21:25 am »
it's basically unrivaled in its price range (for a new scope). definitely a good buy.
"This is a one line proof...if we start sufficiently far to the left."
Offline nanofrog
Re: First Scope
« Reply #3 on: September 15, 2014, 03:29:07 am »
Unrivaled value right now for a scope, and would make an excellent starter unit that you won't out-grow very quickly IMHO.  8)
Re: First Scope
« Reply #4 on: September 15, 2014, 04:31:41 am »
Thanks! I just placed the original.
