Author Topic: Fluke 732B replacement handle and support arms  (Read 823 times)
Offline volvo_nut_v70Topic starter
« on: September 14, 2022, 05:34:15 pm »
I recently received a pair of Fluke 732B, both with damaged front posts. The root cause is that the support arms for the handle are extremely weak because of minimal material around the screw hole where the arm is fastened to the handle. One arm will break and with the weight of the battery the other fails and the 732B is on the floor with plastic bits strewn about. I was also missing one handle.
From Fluke the handle is $160, the arms are $20 each. The handle screws are $9 each. The new support arms are the same design and material so it will fail again.
I had my machinist friend fabricate a new handle and support arms out of aluminum, photos attached.
My question is there a want / need out there for the handle and support arms? What are people's thoughts. The handle and arms do not lend themselves to CNC machining (my friend is capable in both) so it is manually machined. He doesn't consider it complex machining.
The arms are compatible with the original handle.
The aluminum handle and arms could be anodized black, I haven't priced it out and pricing depends on quantity being done.
For straightening out a bent post I used a #24 transfer punch inserted all the way down the post hole and gently tugged the post straight.
The following users thanked this post: ManateeMafia
Offline HighVoltage
Re: Fluke 732B replacement handle and support arms
« Reply #1 on: September 14, 2022, 06:09:07 pm »
First I need a Fluke 732B!
Nice handle, the way it should have been done by Fluke.
