Author Topic: Fluke 87 multimeter  (Read 20425 times)
Offline coromonadalix
Re: Fluke 87 multimeter
« Reply #25 on: December 19, 2018, 10:19:33 am »
@ electro   dont forget the super capacitor issue in 189 and 289
Have ordered 5 battery clips kit from fluke usa,  yeah 5x kits lots of $$,  and got 5x supercaps at 1.60$ each,  changed the 3 in my 189's, they were oxydized, one has begun to drain the battery. Changed 1 battery clips kit.
If your patient  you can snatch very good meters on the web.
Took me a while to get my 189's and the extended battery packs bp-189, they dont cost a fortune to calibrate :) and i love the fact you dont have to always open the case for the fuses and battery replacement.
The 8x series at my job had battery had clips changed, some dial switch problems (resolved with an good cleaning), damaged thread screws (opened too often for fuses change and battery change)
Even had an Mastech 20,000 count ms8340 first generation who had the 2 hrc fuses in the battery compartment,  made an error to re-sell it, the newest ones have only 1 hrc fuse.
« Last Edit: December 21, 2018, 02:50:38 am by coromonadalix »
Offline joeqsmith
« Reply #26 on: December 19, 2018, 01:44:41 pm »
The Fluke 289 on eBay is only the master lead set for $164.99 I would probably need to bid on a used one.
I saw your original post and was thinking, that was a great deal for a brand new 289.   :-DD
Offline albert001Topic starter
« Reply #27 on: December 19, 2018, 05:48:09 pm »
I've been using a 75 for quite a while just around the home mostly to test voltages, resistance and continuity.
I'm uncertain if I  need the features of the 87 when compared to the 79, as I only use a DMM around the home and testing circuits in automobiles. Perhaps could use a more advanced DMM but am uncertain.
For the work you describe I'd get a Fluke 101.
Really safe/robust, no need to mess about with dodgy old zebra strips and the unknown history of a 20 year old meter, $45 delivered to your door.
Yes that's probably true a Fluke 101 or similar should  work most of the time for basic testing voltages, continuity and resistance.  I use to be more into electronic repair using various types of electronics test equipment such as oscilloscopes, bench meters, etc. I still have an old 10Mhz oscilloscope in storage and a few test probes and leads.
I'm not really certain if I need something with more features for around the home and working on automobiles. I have some older automobiles with more sophisticated electronics. E.g. I'm trying to repair a VIC (vehicle information center) module that has problems as it ages of the circuit boards developing micro cracks I'm told due to the manufacture used lead free solder it's two circuit boards tends to develop micro cracks  over time. Solution is to re-solder the boards and replace any bad caps.
I have an option to return the Fluke 79 that's suppose to arrive this Friday. I can just refuse the shipment and it will be returned to sender.
Offline blacksheeplogic
« Reply #28 on: December 19, 2018, 07:40:16 pm »
I would also be looking at a 101 in preference a 20 year old 89 if the 101 meets your needs.
« Reply #29 on: December 19, 2018, 11:29:16 pm »
I think I'll look around for an 87 or 289 if can find a used one at a good price. There is one that's suppose to be new on eBay for $380.00 or best offer.
The 79 even though the eBay seller has a 14 day return policy, won't accept a return unless the meter is doa or somethings not working.
Stated the reason is he has to pay for a warehouse and people to package his  items. Also  I paid $20.00 for shipping which isn't refundable.
So if unable to return the 79 and it wouldn't make any sense to purchase a 101 if having a 79 III to use.
Hasn't arrive yet. Is described as "in excellent working condition"
https://www.ebay.com/itm/123465753442
« Last Edit: December 26, 2018, 09:05:24 am by albert001 »
Offline Electro Detective
« Reply #30 on: December 20, 2018, 08:54:03 am »
@ electro   dont forget the super capacitor issue in 187 189 287 and 289
I hear you mate, I didn't want to scare off the OP about that, or continue the ongoing saga already at other posts here.
My 189 and 289 still have those infernal bearded supercRapacitors inside,
not leaking but most likely open? or shorted? by now, whichever state no longer affecting the main battery draw AFAICT.
I've been meaning to get them out, but too many conflicting stories about what to replace them with
and possibility of killing the meter in doing so,via ESD pops, firmware/software nukes etc etc  :scared:  = too much thinking, setting up a temp micro rig to see and solder,
basically no thanks$$$ for now  :--
I just keep an eye on the souperclapacitors for further leakage, and re-do the clock/s on battery changes.
If someone (Fluke Support...where are you? I hear crickets chirping... ::)) documented the CORRECT way to do it with a long term parts replacement, I'd have it done yesterday.
i.e. in this case I adhere to "don't fix it if it ain't totally broke...yet"
Anyways, both meters work great and agree on the displays, so I let sleeping dogs and supercrapacitors lie for now
Good luck with your parts swap ordeal.
Offline ender4171
« Reply #31 on: December 20, 2018, 02:27:27 pm »
This is topical for me.  My only two meters just happen to be an 87V and a 289.  I like them both, but if I was buying a single meter, I would 100% go with the 87V.  The 289 is feature rich, but I rarely have use for the logging (and would probably use my scope anyways) and the drawbacks outweigh those features for me.  It is massive, heavy, sucks down batteries, and is fragile compared to the 87 (look up the IR diode issue).  If you think you will use the added features or just want the fancier of the two, the go with the 289.  If you are looking for a rock solid meter you can probably run over with a car, that is easy to use and not overly complex, go with the 87V.
The following users thanked this post: Electro Detective
« Reply #32 on: December 20, 2018, 10:08:40 pm »
I found a 87 V for $150.00
For the 79 III I tried to get the seller to issue a refund and he messaged that couldn't issue a refund based on "Change my Mind"  I then asked him about a partial refund and would only offer a $40.00 refund.
He also said he has a different address for returns, so if he sticks to that I would need to pay for return shipping instead of refusing delivery. If you refuse USPS deliveries and the package hasn't been open USPS will send a package back to the return address at no cost.
He had it listed with a 14 day return policy without any conditions such as only if DOA, not as described, so I'm going to let eBay decide. eBay's fairly good at handling returns and getting sellers to issue refunds.
If not able to get a full refund minis the $20.00 for shipping I'll probably keep the 79 III or put it up for auction.
Here's a link to the 87 V I got for $150.00, (best offer accepted) appears to be in good condition.
https://www.ebay.com/itm/332966922166
Offline mzacharias
« Reply #33 on: December 20, 2018, 10:20:22 pm »
Can anyone tell me if an 87IV has that supercap?
They don't do logging...
I can tear mine open and look, I suppose.
Offline retiredcaps
« Reply #34 on: December 20, 2018, 11:05:37 pm »
The 87IV and 187 don't have the supercap.
The following users thanked this post: mzacharias, Marco1971
« Reply #35 on: December 20, 2018, 11:37:45 pm »
You can refuse delivery, it's not actually your problem if the seller uses a different return address to his shipping address.I think he's probably trying to make you accept the delivery to save cost.
However, in terms of what is right or wrong, this is a really grey area, if I was the seller and had honored my part of the transaction I think I would expect you to honor your part of the transaction. It does not feel right that the seller lost sales opportunity, and incurs a cost just because you changed your mind AFTER they shipped.
The following users thanked this post: bc888
« Reply #36 on: December 21, 2018, 04:54:02 am »
I'm betting once OP has the 79 and 87V in the tool pouch, and used/alternated both on a few tasks   :-DMM :-DMM
...neither model will hit an auction site any time soon  ;D
It's a Fluke thing, been there...  ::)
Offline BravoV
  • +++ ATH1
« Reply #37 on: December 21, 2018, 05:02:51 am »
As owner of 87V, 189 and 287, reading your preference above, once you used 189, you will never look back.  :P
Think of the instantaneous boot speed of 87V, features wise close to your 289, and yet with big & sharp segmented LCD display compared to the shady dot matrix of 289, and not that "bricky".  ::)
Personally I see the Fluke 287/289 series as not a DMM, they're more like a low speed but with high resolution handheld oscilloscope.
« Last Edit: December 21, 2018, 05:16:25 am by BravoV »
The following users thanked this post: Marco1971
« Reply #38 on: December 21, 2018, 05:15:28 am »
I agree, but any yay! owner  :-DMM of a 189 needs to sort out the supercrapacitor issue asap
and keep a sharp watch on the four AA batteries.
If (+when...) they leak, the slime can/will corrode the terminals right along to the main board
to really get the resto party started   :horse:
Offline BravoV
  • +++ ATH1
« Reply #39 on: December 21, 2018, 05:19:16 am »
Yeah, thats the nasty part, both mine already refreshed with much better and long life ultra cap.
« Reply #40 on: December 21, 2018, 09:28:02 am »
I found and settled on a Fluke 87 V for $150.00 (best offer accepted) that appears to be in decent shape and within my price range.
https://www.ebay.com/itm/Fluke-87v-True-RMS-Digital-Multimeter-with-test-probes-clean-87-V/332966922166?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Didn't  come with a rubber protector, so  found a new fluke rubber protector H80-E for $25.00 on eBay and also an aftermarket hard type case for $8.00
I suppose if I could have spent another 50.00 - 100.00+ dollar and find a Fluke with more features, etc. however the 87 V has many good reviews and I think should meet my needs.
I'm not certain what to do with the 79 III i.e. to keep it as a spare or to try and sell on eBay if not able to get a refund.
The seller isn't really responding well to his 14 day return policy that he has listed on his auction. So far has offered me a $40.00 then $60.00 partial refund. The 79 III cost me a total of ~$110.00 with shipping. I'm going to let eBay deal with the return of which I believe they will ask him to refund the full amount minus the $20.00 paid for shipping.
If unable to get a full refund will either keep the 79 III as a spare DMM or put it up for auction on eBay to see if able to recoup some of my cost.
I've been member as buyer and seller on eBay since the 1990s and still have 100 percent feedback as I've never stiff anyone and have always bent backwards to satisfy buyers. I honor any 14+ days return policy no matter the reason why a person wants to return an item.
As a seller, If I don't want a buyer returning an item I then either auction an item as-is (no returns)  or include a condition that an item can be returned only if DOA or not as described.
« Last Edit: December 21, 2018, 11:56:17 am by albert001 »
« Reply #41 on: December 23, 2018, 08:57:53 am »
If the 79x works perfectly, you may consider to keep it for a while... and or know you'll get better money for it if it does hit Ebay
or flog it here at EEVblog  :clap:
Those input sockets on both meters may/will need a careful clean,
meter front pointing facing down, moist Q-tip/cotton bud with a contact cleaner lube like Servisol
or even WD40 etc if you can't afford to mortgage the house and car  like most electronics hobbyist/DIYbattlers, to buy Bonzai sized tins of De-oxit
and the lead plugs may need CAREFUL adjustment of the (+) shaped prongs if they are original Fluke leads.
CAREFUL means they'll bend back easily and break easily if you force something in the gaps to split them out,
just a little working goes a long way so that they look like this when viewed  (+)
i.e. four even, not too wide gaps in a cross shape, with a perfect easy fit when plugged into the meter
Hope it made sense...   ???
« Reply #42 on: December 23, 2018, 10:23:04 am »
I'll probably need to clean up both meters some. The internals of the 79 are really clean but the yellow rubber is dirty. From what I read online Fluke rubber protectors can be cleaned with a hand cleaner.
The 87 V hasn't arrived. I ordered a FLUKE H80-E rubber protector as it didn't come with one, plus an afermarket hard case to store it in.
As suggested I'll take a look at the input sockets of both meters. You're saying to clean them with some contact cleaner with lubricants? All I have on had is the CRC contact cleaner, which should have some lubrication.
The 79 so far is working perfectly. I'm thinking of just keeping it for general all around use, putting less wear on the 87 V. I'm uncertain of the leads that came it, they have push clips with soldered on banana jacks.  The neg lead needs to be re-soldered.
I have some other test leads. A pair of  Fluke 1000V Cat III 600V Cat III, the banana  jacks are concealed  and  90 degrees. I also have an pair of Agilent 1000V in storage only used a few time the jacks are also concealed and straight. An  older set of leads that are braided, with alligator clips I'm not certain what decade these are from I don't think you can find them new any more. Haven't seen them around. There more flexible than the more modern rubber  leads.
And another set included  with the Fluke 87 V.
Also found a Blue Point EETA502A AC/DC Clamp Adapter
« Last Edit: December 23, 2018, 06:08:07 pm by albert001 »
« Reply #43 on: December 24, 2018, 03:07:39 am »
I think I'm going to just cancel (close) the return.
Since I first wrote to the seller about a return before initiating a return. It's unclear whether the return is a full refund or $60.00.
When I started a return I was already communicating about a refund or partial refund and he wrote back saying he would refund $60.00.
So the refund amount is unclear. My phone doesn't work at my location to telephone eBay and there's no ebay contact or ask eBay to step in link from the return details.
I never did ask eBay to step in so I suspect the refund amount would be what the seller stated in ebay messaging.
I wrote to the seller about it but haven't heard back and I'm tired of messing with the whole thing.
I've never had this problem in the past when contacting the seller befor initating a return.
So in the future if needing to return an e-bay item will first initiate the refund before communicating with the seller.
Imo it's a  good  quality dmm without alot of features, more for general all around use. There's many things you can do with a 79 III.
I can use it as a backup or to test other multi-meters. For general use it will take some wear off the 87-V.
Fluke 79 III service manual
« Reply #44 on: December 25, 2018, 02:11:09 pm »
Found a calibration manual for the Fluke 79 III but I don't think there's any  service manual available online for the series 79 Series III?
Offline GeoffreyF
« Reply #45 on: December 25, 2018, 06:41:10 pm »
Leave the higher tech meters for the EE's to Brymen.
 :rant: :rant: :rant:
what do You mean? any brymen advantages above flukes?
Read the specifications and see if you can figure it out.   What so many here fail to realize is that "the best" depends on what you do with it.  Each has a price and function benefit or it would not be on the market.   The post you respond to directly addressed this point of different tasks for different meters.
For casual hobby use, almost any meter is fine.  In fact, low cost is good if you are not used to electronic work.  If you wreck it then there are fewer tears.
US Amateur Extra W1GCF.
Offline ct1bxt
  • Country: pt
« Reply #46 on: December 26, 2018, 01:19:14 am »
I own an 189 for a long time and it work all the time very good.
Last year bought an Brymen BM-869s and from few week ago an Agilent U1253b.
Still like to use the 189 but currently the most I use is the BM869 and the U1253b.
The brymen is fast as one more digit and very important to me, as I became holder, the display digits are bigger.
Also records the last switch mode, i.e. if the last I was checking for continuity, when switch on next time, he will in continuity mode.
The Agilent is good for dark spaces were the oled makes the difference.
As I said previously I still like the 189 as he works very well with components under RF.
Rodrigo
« Reply #47 on: December 26, 2018, 06:25:54 am »
Partially because the return is ambiguous and other reasons I decided to cancel the return and keep the Fluke 79 III.
I think it's good enough for most automotive and around the house repair and diagnostic work.
I noticed some of the specifications of the Fluke 77 IV exceed the 79 III. The Fluke 77 IV has min/max and range buttons  is 6000 count vs 79 III 4000 count.
 I haven't been able to find a user or service manual for the Fluke 79 III.  There is a service manual for the Fluke 79 series II but no series III can be found.
« Last Edit: December 26, 2018, 09:17:38 am by albert001 »
Offline mzacharias
Re: Fluke 79 III service manual
« Reply #48 on: December 26, 2018, 07:26:17 pm »
The 77III and 79III is the same service manual.
I have a copy if you'd email me at [email protected]
The file size is a bit too large to upload here.
I will also upload to
http://www.ko4bb.com/getsimple/index.php?id=manuals
but there is some latency before it will appear there.
« Reply #49 on: December 29, 2018, 05:11:14 am »
Ok, sent an e-mail for the Fluke 79 Series III service manual.
The 77 and 79 series III service manual are probably nearly the same, however some specifications  of the 77    are different from the 79.
e.g. 77 Series III display is
Display Digital: 3,200 counts, updates 2.5/sec
Analog: 31 segments, updates 25/sec
Where the 79 Series II Is
Digital: 4000 counts, updates 4/sec
Analog: 63 segments, updates 40/sec
Frequency: 9,999 counts
Capacitance: 9,999 counts
Response Time 9,999 counts
