Author Topic: A DMM upto 20$ with PC connection for logging?  (Read 2986 times)
Offline TomerPTopic starter
  • Country: il
« on: August 19, 2017, 04:33:03 pm »
Hi, is there a DMM with a PC connection for logging (either USB/COM) that also costs less than 20$?
Offline jpb
Re: A DMM upto 20$ with PC connection for logging?
« Reply #1 on: August 19, 2017, 05:06:01 pm »
It would probably need to be second hand if there was one.
If accuracy is not that important then alternatives such as the analogue inputs on a rasberry pi might be an option.
Online Lightages
  • Canadian po
« Reply #2 on: August 19, 2017, 06:35:51 pm »
The least expensive data logging meter that I know of is the Digitek DT-4000ZC, also known as TekPower TP4000ZC. They sell for around $40.
Offline retiredcaps
« Reply #3 on: August 19, 2017, 11:16:39 pm »
It first sold for around $29 USD when I brought it to Martin's attention 5+ years ago.  Then it got popular and sellers raised prices.
http://www.mjlorton.com/forum/index.php?topic=81.0
Offline Fungus
« Reply #4 on: August 21, 2017, 12:22:56 am »
What do you need to measure? How accurate?
  • Country: il
« Reply #5 on: August 28, 2017, 06:36:54 pm »
Vdc and Current, as accurate as 1% I guess.
Offline Fungus
« Reply #6 on: August 28, 2017, 06:49:34 pm »
How many volts? How many amps? Will you need to switch voltage ranges or is it fixed?
  • Country: il
« Reply #7 on: August 28, 2017, 07:00:16 pm »
220v ac, much less dc, up to 30 amper (I don't know if its a reasonable requirement for that price range)
Offline Fungus
« Reply #8 on: August 28, 2017, 07:45:46 pm »
a) You don't really need to measure 220V AC, it hardly ever gives a wrong value (not unless you're using a generator or something).
b) Look into current clamps for Arduino.
https://encrypted.google.com/search?q=arduino+current+clamp
« Last Edit: August 28, 2017, 07:47:38 pm by Fungus »
  • Country: il
« Reply #9 on: August 28, 2017, 08:45:15 pm »
true, but measuring dc voltage of up to lets say 50v is something I'd like to be able to do with it
Offline Fungus
« Reply #10 on: August 28, 2017, 08:53:19 pm »
Make a 10:1 resistor divider, connect it to the Arduino.
