Author Topic: Fluke MicroScanner Pro Wiremap adapter  (Read 595 times)
Offline Salient666Topic starter
  • Ohm Sweet Ohm
    • Wavetable.nl
« on: July 24, 2026, 01:47:01 pm »
A shot in the dark, but does anybody have the schematics for the Fluke MicroScanner Pro Wiremap adapter? This is the old version, see photo.
Buying 6-1/2 digit bench multimeters just to check if a regular nine-volt battery is still alive.
Offline kripton2035
Re: Fluke MicroScanner Pro Wiremap adapter
« Reply #1 on: July 24, 2026, 05:10:26 pm »
The following users thanked this post: Salient666
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #2 on: July 25, 2026, 03:18:10 pm »
I decided to just open up mine and measure the connections.
See photo with what I found.
Some strange resistor values used.
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #3 on: August 08, 2026, 12:30:19 pm »
In the meantime I have built it with through hole components on a standard PCB, and it works flawlessly, tested all sorts of wiring errors and all came through as it should.
  • Ohm Sweet Ohm
    • Wavetable.nl
« Reply #4 on: August 25, 2026, 02:44:35 pm »
I finished two of my home-made wiremap adapters now.
Finally found good use of the yellow filament. :)
