Author Topic: Fnirsi SG-003A & SG-004A Signal Generators  (Read 49970 times)
Offline Aldo22
Re: Fnirsi SG-003A & SG-004A Signal Generators
« Reply #100 on: July 04, 2026, 09:28:56 pm »
aside from the incorrect revision output, not much is working right off the bat.
Which parts are you referring to?
I played around with the Python demos a bit today and made some changes.
It worked perfectly for me.
Of course, I didn't test anything out of the ordinary.
> python3 example_usage.py
1. Reading current input signal configuration...
Current input signal configuration:
  Signal Type: 2 - Voltage
2. Reading current output signal configuration...
Current output signal configuration:
  Signal Type: 1 - Current
3. Reading output switch status...
Output enabled: False
4. Changing output signal to voltage mode...
5. Turning output ON...
Setting Output Value: 0.2
Current Input Value: 0.2031
Setting Output Value: 0.3
Current Input Value: 0.3028
Setting Output Value: 0.4
Current Input Value: 0.4044
Setting Output Value: 0.5
Current Input Value: 0.5013
Setting Output Value: 0.6
Current Input Value: 0.6019
Offline Martin72
« Reply #101 on: July 04, 2026, 09:44:18 pm »
I tested this first with my Modbus Poll software.
That’s why I suggested to Fnirsi that they use the standard function codes specified in the protocol standards, so that standard software like Modbus Poll can be used to its full potential.
Right now, I’m only using the test board with a simple input console.
If I can’t get any further with that, I’ll take a look at the Python program.
Offline BillyO
« Reply #102 on: July 05, 2026, 01:20:28 am »
In a nutshell, how does this compare to the LB06?
I guess no one that has one of these also has an LB06.  Maybe I'll buy both and compare.  Who knows, I done dumb shlt before.   :palm: :scared:
Bill
Offline Aldo22
« Reply #103 on: July 05, 2026, 10:00:15 am »
I only have the SG-003A (the SG-004A has more features, is more accurate, and more expensive), but based on the information available, I’d say these devices differ quite a bit from the LB02/LB06.
Here are a few main differences I’ve noticed:
The LB0x models can’t measure and output at the same time because they only have two ports. The SG-00xA models have four ports.
The LBx models have a basic LCD display, while the SG-00xA have a color display that can also show graphs (attached photo).
LB0x models can only output 0–11 V, while the SG-00xA can output 0–24 V.
The SG-00xA models are calibratable.
The SG-00xA models are programmable (e.g., increase the voltage by 100mV every second).
etc.
As I said, I’m not personally familiar with the LB0x models, but I’ve noticed these differences (without guarantee).
I’m sure the LB0x models also have certain advantages. For example, the LB02 is more accurate than the SG-003A, but SG-004A is also accurate.
The SG-003A is the least expensive of them all.
I think you have to compare the specifications carefully and decide which features are more important to you.
« Last Edit: July 05, 2026, 10:15:46 am by Aldo22 »
The following users thanked this post: BillyO
Offline Martin72
« Reply #104 on: July 06, 2026, 09:29:07 pm »
I've made some progress already.
My testing is based on Fnirsi's datasheet regarding the protocol and the Excel spreadsheet from the post:
https://www.eevblog.com/forum/testgear/fnirsi-sg-003a-sg-004a-signal-generators/msg5966599/#msg5966599
However, the table contains errors; I'm working on a correction based on tested results.
As I said, all of this was done using Modbus Poll's “Test Console.”
Here's what I've managed to do so far:
Read the firmware (even if the value is wrong—that's on Fnirsi)... ;)
Read and write output values; read and control the output switch status.
Bit by bit, I'm working my way through Fnirsi's data protocol.
That way, you understand it better than if you just used a ready-made program, and you can modify it as needed.
Here is a link that converts the float values to hexadecimal, which you can then use in the data telegram.
https://gregstoll.com/~gregstoll/floattohex/
If you're using a terminal program that doesn't automatically generate a CRC, here's a CRC calculator tool:
https://www.lammertbies.nl/comm/info/crc-calculation
Martin
Online KungFuJosh
  • TEAS is real.
« Reply #105 on: July 06, 2026, 09:49:53 pm »
TestController supports ModBus. If you really like this device, you could make a TestController driver definition for it. ;)
Best Continuity Tester Ever
Offline Martin72
« Reply #106 on: July 06, 2026, 09:56:49 pm »
Right now, I'm actually only interested in the device because of its Modbus interface.
The reason is that we (the company where I work) also offer a Modbus interface for some projects, and I had developed a test device (a Smart Display acting as a Modbus master) so that my colleagues wouldn't have to waste time counting bytes... ;)
Of course, we use a standard Modbus protocol in accordance with industry standards; the Fnirsi device appeals to me precisely because it doesn’t have that. :-X 8)
Online KungFuJosh
  • TEAS is real.
« Reply #107 on: July 06, 2026, 10:14:06 pm »
“It's the imperfections that make something beautiful. That's what makes it different and unique from everything else.”
― Bob Ross
 :-DD :-DD :-DD
The following users thanked this post: Martin72, Aldo22
Offline Aldo22
« Reply #108 on: July 07, 2026, 08:25:29 am »
My comparison above with the LB0x gave me an idea:
Is it possible to plot a diode characteristic curve using just two wires with the SG-003A without any additional equipment?
Yes!
- Output: V, Input: mA
- Programmed voltage rise
- Curve display
In the image: Yellow is voltage, blue is current.
The graph is a bit cramped because I chose a 0–4 V range; it could be made to look nicer, but you can see the point.
You might not "need" this, but an LB0x definitely can’t do this.  ;)
« Last Edit: July 07, 2026, 08:30:49 am by Aldo22 »
The following users thanked this post: BillyO, Martin72, tutochkin
Offline Kurt_!
  • Country: at
« Reply #109 on: September 27, 2026, 10:27:55 am »
They ran out of yellow paint for my SG-004A?!
Oh...my English...
Offline Kurt_!
  • Country: at
« Reply #110 on: September 29, 2026, 12:18:15 pm »
I have another question.
My device arrived with a 60% charge.
I almost fully charged it.
But...it took a very long time!
A 5-volt, 2-amp charger was included.
It works (tested).
Unfortunately, the device only draws 1-2 watts.
My Ugreen charger charges at 10 watts.
The SG-004A is supposed to charge at 5 to 12 volts.
Is it normal for it to take so long and charge so weakly at 5 volts?
Oh...my English...
The following users thanked this post: Mike1233
Offline Filippo52
« Reply #111 on: September 29, 2026, 02:23:19 pm »
I can comfort you.
The included charger...it sucks.
But the supplied USB-A to USB-C cable sucks even more.
Just change the cable to significantly increase the wattage, up to 5W.
If you use a power supply capable of negotiating according to the USB-PD 3.1 standard, the device will negotiate 12V and you can get about 10W.
If you look at the power supply ripple on the oscilloscope, you'll want to change it too.
Filippo
The following users thanked this post: Mike1233, Kurt_!
