EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Frequency Counter Input Buffer
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Frequency Counter Input Buffer (Read 2001 times)
ko4nrbs
Regular Contributor
Country:
on:
November 05, 2022, 01:39:38 pm »
Any suggestions for a buffer for this counter?
https://usa.banggood.com/1Hz-50MHz-High-Sensitivity-Frequency-Meter-Counter-Measurement-Tester-Module-7V-9V-50mA-p-1662557.html?cur_warehouse=CN
I tried a pickup coil but couldn't get it to pick up the signal. I am trying to check the output frequency of an old Heathkit HG-10 VFO. Its output is at 5 volts RMS open circuit.
Thank you,
Bill
Logged
BillyO
Super Contributor
Country:
Re: Frequency Counter Input Buffer
Reply #1 on:
November 05, 2022, 02:30:58 pm »
You could possibly make up something with a high GBP op amp.
Logged
Bill
ledtester
Super Contributor
Country:
Reply #2 on:
November 05, 2022, 02:49:16 pm »
I have this kit and built it but I can't remember if it came with a schematic or not.
In any case, in this thread:
https://antiqueradios.com/forums/viewtopic.php?f=8&t=391757
I found a reconstructed schematic which shows the input section:
Logged
ko4nrbs
ko4nrbs
Regular Contributor
Country:
Reply #3 on:
November 05, 2022, 03:19:49 pm »
Do you use an input buffer with it?
Bill
Logged
Grandchuck
Super Contributor
Country:
Reply #4 on:
November 05, 2022, 03:32:54 pm »
You could try one of these:
https://www.aliexpress.us/item/3256802963755345.html?spm=a2g0o.detail.1000060.1.9ab4792duzHSa7&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.291025.0&scm_id=1007.13339.291025.0&scm-url=1007.13339.291025.0&pvid=9e709335-b039-46f3-b2ef-704b3131bb58&_t=gps-id%3ApcDetailBottomMoreThisSeller%2Cscm-url%3A1007.13339.291025.0%2Cpvid%3A9e709335-b039-46f3-b2ef-704b3131bb58%2Ctpp_buckets%3A668%232846%238113%231998&pdp_ext_f=%7B%22sku_id%22%3A%2212000024369199718%22%2C%22sceneId%22%3A%223339%22%7D&pdp_npi=2%40dis%21USD%213.76%212.9%21%21%21%21%21%402101d1af16676622808262566e0ffc%2112000024369199718%21rec&gatewayAdapt=glo2usa&_randl_shipto=US
Logged
ledtester
Super Contributor
Country:
Reply #5 on:
November 05, 2022, 06:05:49 pm »
Quote from: ko4nrbs on November 05, 2022, 03:19:49 pm
No I haven't used it with an input buffer. I haven't gotten around to using it with RF signals.
Logged
ko4nrbs
Regular Contributor
Country:
Reply #6 on:
November 06, 2022, 04:53:05 pm »
Hooked it up directly to my old Tektronix Constant Amplitude Signal Generator (Type 191) and the counter worked perfectly.
Bill
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
