I recently acquired a used KKMoon-branded FY6800 signal generator. Everything works well except for one thing. The rotary encoder sometimes skips backwards or forwards one digit. It's annoying, but usable. I'm assuming that the encoder is mechanical rather than optical. Probably the contacts inside are just dirty.
So, repair, replace, or leave it alone? Is the encoder reasonably easy to clean? I have both a DeOxit equivalent, and some home electrical contact cleaner with oil. Or does cleaning it significantly risk ruining it? Is an equivalent part available in the U.S.? I can solder and unsolder reasonably-sized components.
Also, can the 6800 be run off of 5v only, such as a 5v linear wall wart or a power bank? Or does it require 12v as well? I've read conflicting reports about this. I was thinking of installing a standard barrel connector across the 5v rails for alternative power (with AC mains disconnected, of course).
I must say, this little box may not be adequate for commercial electronics development, but I think it will serve me well for aligning and troubleshooting ham radio equipment. And it's been a great tool for teaching myself how to use my digital oscilloscope. Honestly, its newer descendants don't offer that much more for me. Especially since their prices have now risen to the same ballpark as UNI-T and Owon, and even bordering on Siglent and Rigol entry-level territory.
Thanks!
--Peter
