Author Topic: Good multimeter for an Industrial Tech  (Read 14156 times)
Offline Matt HatterTopic starter
« on: August 31, 2017, 12:34:39 am »
Hey all, I am currently employed as an industrial maintenance and repair tech and find myself in need of a better, and more importantly safer meter. There is the obvious Fluke 87-V, but I have also seen similar models by FLIR and other manufactures and was wondering if you all had any suggestions. The primary usage case for the meter will be high voltage (220-480 volts) mains and motor wiring, etc. Not afraid to spend a bit of money as the meter is the only thing between me and death haha. I've included a link to several FLIR meters below.
Cheers
http://www.flir.com/instruments/dm90/
http://www.flir.com/instruments/dm9x/
« Last Edit: August 31, 2017, 05:04:30 pm by Matt Hatter »
Offline shteii01
Re: Good multimeter for Indutrial Technitians
« Reply #1 on: August 31, 2017, 01:27:52 am »
If I recall correctly FLIR is owned by the same company that owns Fluke.
I would suggest Fluke 117.  It has a feature to detect live wire remotely.  Has backlight.  You can get "refurbished" from Fluke direct, with 3 year warranty, but it will probably not have any of the standard accessories: https://www.flukeonlinestore.com/products/factory-reconditioned/fluke-117-electricians-true-rms-multimeter
Then there is ebay too.
Check local pawn shops.  I couple of weeks ago I saw Fluke 177 and Fluke 179 in the same shop.  177 was under 100 USD.  179 was just over 100 USD.  Of course they are used and for all we know they might be fried so inspect before you buy, bring some known value resistors and batteries to try them out before you buy.  If you have local university with some kind of engineering program, you can swing by and see if they keep labs open, and take measurements of the components.  That way when you try the meters with those components you will know exactly what the meter should read.
There are also Agilent/Keysight surplus/new old stock meters on ebay for around 200 USD.
I bought from this seller the B model.  Seems they are out of B and only have A model: http://www.ebay.com/itm/Agilent-U1252A-With-Carrying-Case-/292214966352?hash=item44095e8850:g:p7wAAOSwXXxZPdz9
« Last Edit: August 31, 2017, 01:31:41 am by shteii01 »
Online Lightages
  • Canadian po
« Reply #2 on: August 31, 2017, 04:13:03 am »
I can highly recommend a Brymen BM089. Having a clamp meter is a very good thing for industrial uses. This meter also measures 3 phases at once:
http://www.tme.eu/en/details/bm089/meters-and-acdc-clamp-probes/brymen/
Offline retiredcaps
« Reply #3 on: August 31, 2017, 05:02:59 am »
No they are competitors.
I buy my meters used and abused, but I will NEVER use them like the OP in high voltage mains.
I recommend buying new from an authorized reputable dealer so you don't get one that has been abused.  And I also suggest never lending out your meter.
The following users thanked this post: Lightages, Electro Detective
Offline DaJMasta
    • medpants.com
« Reply #4 on: August 31, 2017, 06:43:28 am »
Too many stories of fuses being jumpered over and whatnot to trust a used meter for high power use unless you're willing and capable to open it up and verify it yourself.
Fluke seems like a good go-to as they've sort of made their name on stuff like this, but there was a thread discussing at least one Brymen meter in an industrial application and the guy using it seemed to be quite pleased overall, maybe worth a search.  I've been quite happy with my Brymen too, but I don't deal with those voltages generally, so my usage case probably doesn't apply all that well to the OP's.  I remember Dave did some comprehensive durability tests on some of the Keysight meters, they seemed like they held up well.  Keysight currently has at least two meters rated IP67 and CAT III 1000V / CAT IV 600V.
Don't know if you've already considered it, but once you find a meter you consider up to your standards, maybe look at going with probes with a more comprehensive guard or better insulation rating too.  A capable meter will probably come with good ones, but getting probes that are easy to use with all the safety precautions in place and that are comfortable and grippy in your hands may be slightly different than the ones supplied with the meter.  Worth considering, maybe not necessarily required.
The following users thanked this post: Electro Detective
Offline Fungus
« Reply #6 on: August 31, 2017, 09:36:27 am »
I wouldn't say Fluke87V is the best for your job. The 87V is for electronics engineers - you don't need 0.05% accuracy when looking at big motors, you don't need to measure capacitance. You probably don't even need amps (and if you do, you'll be using a clamp because the 87V can't measure that many amps).
Fluke makes meters for industrial electricians as well as electronics engineers, eg. Fluke 117 (which also has non-contact voltage detector).
First job: Make a list of what it is you actually measure.
Second job: Find a meter that matches that.
If you measure a lot of current you can get a meter with built in clamp, eg. Fluke 381 which has detachable display and everything.
If you worry about safety and you're open to non-Fluke then don't mess around, get an AMPROBE HD160C. It's the only CAT IV 1000V meter (that I know of). You'll be able to point at Fluke 87V owners and laugh at how unsafe their meters are.
http://www.amprobe.com/Amprobe/usen/digital-multimeters/Industrial-Multimeters-/AMP-HD160C.htm?PID=73247
It's also cheaper than an 87V and the magnetic hanger is included, not just a photocopy of one.   :-DMM
« Last Edit: August 31, 2017, 09:58:13 am by Fungus »
Offline Electro Detective
« Reply #7 on: August 31, 2017, 10:16:39 am »
Get a NEW 87V, bang it on your tax deductions and get on with the job,  :-+
I doubt the 117 will give any AC reading past 666 volts much less test and verify an insulation test/er at 1000v DC, it's CAT rating may be iffy in a 480 volt 'situation'
and that's not good in an  'anything goes on a bad day'  industrial maintenance and repair situation  :-//
Get a good AC+DC TRMS clamp meter too,
current capabilities on multimeters blows, and so do the fuses
and sometimes the clumsy operators too   >:D
BTW: Has the AMPROBE HD160C received a good electrical thrashing and field trashing yet?
Till then, I stick with the yellow...   :-DMM
« Last Edit: August 31, 2017, 10:21:33 am by Electro Detective »
Offline shteii01
« Reply #8 on: August 31, 2017, 10:18:31 am »
200 USD?  Current measurement 2 A?  Have you lost your mind?
My 100 USD Fluke 27FM rated for 10 A and I bought it used from ebay.
Over the weekend I am going to the customer, the system I will be working on is set for 3 phase 460 VAC and 30 A.
Offline Fungus
« Reply #9 on: August 31, 2017, 10:22:08 am »
That, too.
Or get a Fluke 28II, it's a tougher version of the 87V (more or less).
« Reply #10 on: August 31, 2017, 10:24:50 am »
28-11 has a lame diode test and some other issue/s
and you need a kids shopping trolley to lug it around, and pay the kid too    ;D
Offline shteii01
« Reply #11 on: August 31, 2017, 10:25:29 am »
Might as well get 77 since uA are useless in this line of work.
Interesting point about the high voltage machines in the 600 VAC range.
I have never built anything that is more than 460 VAC 3 phase.  I am now on my second job and both places I work built machines for factories.  I have built 120 VAC, 240 VAC, 460 VAC.  Nothing higher.
Is there a lot of machinery being used that is 600+ VAC?
Offline Fungus
« Reply #12 on: August 31, 2017, 10:26:00 am »
In other words: You can't measure the current with the Fluke 27FM, you need a separate current clamp.
Am I right?  :-//
PS: $100 for a used 27FM? I paid $60 for mine and it was new (old stock).
Offline Fungus
« Reply #13 on: August 31, 2017, 10:27:29 am »
Is that a problem when diagnosing 480V industrial motors?
Offline shteii01
« Reply #14 on: August 31, 2017, 10:30:10 am »
Am I right?  :-//
Wrong.
I got A, mA and uA.
Regarding 27FM price.  Different timing.  I know they originally went for 25 USD on ebay.  By the time I got into dmm shopping those prices where long gone, like a couple of years gone.
Offline Fungus
« Reply #15 on: August 31, 2017, 10:30:41 am »
No, but where there's big motors there's big inductance.
Inductance can cause voltage spikes much higher than the input voltage.
Offline Fungus
« Reply #16 on: August 31, 2017, 10:33:35 am »
Am I right?  :-//
Wrong.
I got A, mA and uA.
Can you measure 30A using the 27FM?
Answer: No.
Conclusion: A 2A meter is as useful as a 10A meter for industrial work. "Indutrial Technitians"(sic) usually need a current clamp as well.
« Last Edit: August 31, 2017, 10:37:27 am by Fungus »
Offline nctnico
« Reply #17 on: August 31, 2017, 10:38:30 am »
I'd go for Fluke or Keysight. Both are respected brands and not likely to skimp on safety and if they do they have deep enough pockets to pay for your funeral and loss of income to your family.
« Reply #18 on: August 31, 2017, 10:42:24 am »
Beat me to it    :clap: :clap:
AC capacitor banks run at 660 volts and higher sometimes
If I'm going to be playing tech wizard in a factory with a nagging 'time is money' pushy asshole clueless supervisor,
I want my meter to read 440v and 666v AC, or 1058v DC  rather than   'OL'   (i.e. SOL)  on anything past 600
« Last Edit: August 31, 2017, 10:45:37 am by Electro Detective »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #19 on: August 31, 2017, 10:44:48 am »
What you want to spend? Is the Fluke 1587 FC within budget?
It does everything except non-invasive current. But you could buy an i30s for that, if you grow money.
« Last Edit: August 31, 2017, 10:46:33 am by Jeroen3 »
Offline madires
  • A qualified hobbyist ;)
« Reply #20 on: August 31, 2017, 10:46:11 am »
For mains I'd recommend something like a Duspol. Fluke offers similar testers in case you're a Fluke-aholic.
« Reply #21 on: August 31, 2017, 10:50:47 am »
A Duspol is a MUST HAVE before thinking about any meter    :-+
My T100 has bailed me out of a lot of iffy situations  :-//  :scared:
And a Fluke 1587 FC is a waste of money with lame specs compared to an 87V especially if you don't need its insulation test feature
And it's EXPENSIVE  :o  Nice meter though, but there are much cheaper meters out there with same features
« Last Edit: August 31, 2017, 10:53:35 am by Electro Detective »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #22 on: August 31, 2017, 11:45:19 am »
I don't think it's very expensive if you would have to buy an insulation tester as well. Which I think is a required tool for diagnosing motors and other GFCI troubleshooting.
Offline rjardina
« Reply #23 on: August 31, 2017, 12:00:24 pm »
I would second both of statements. The Brymen BM089 along with the Brymen BM878 (insulation tester) has millamp (4-20)/mill-volt reading and having two meters for temperature readings at once is a must at times for a industrial tech. Both of these meters are my daily drivers too. I've had both of these meter for over a year and a half no problems. Oh as a bonus living in the USA, no one knows this brand, so unlikely someone will steal them either LOL.
Offline oldway
« Reply #24 on: August 31, 2017, 01:23:17 pm »
In industrial electricity and power electronics, NEVER use a multimeter to measure current....that's a basic rule of safety !
Use a clamp instead.
If your multimeter has current input, I recommend to obstruct the current input with silicone or hot glue, so you can't make mistakes.
Buy only Fluke or Brymen brands multimeters.
Test leads are very important for you safety...If they are damaged, replace them only with original test leads and buy them by an official Fluke or Brymen dealer.
The following users thanked this post: Trader
