Surgey, Just so i know, What's the deal with you mate ?
- I'm happy to get on a zoom chat with you and get you over the line, But
- Are you still proceeding with this ?
- have you given up
- have you reverted to just patching the scope,
Hello!
I tried it, but the result is the same.
(Attachment Link)
As I said earlier, or rather wrote, my script gives an error (and I tried to continue as you advised, but it didn’t give anything) and until I can sort this out, I don’t think anything will work out.
I think it’s worth writing to the script developer or to the main forum thread.
ATTENTION SERGEYTHIS POST IS DUPLICATED HERE FROM THE MAIN THREAD FOR THE BENEFIT OF THOSE THAT DON'T SEE THE MAIN THREAD
Mate, You may be in some luck here.
Recently i had a member who had your exact same problem
- After following the standard procedure and then re applying the update and then running the script, it still didn't work.
- We did a bit of troubleshooting and we got there and activated and licensed
CREDIT GOES TO SEPPLETRONICSI have attached A NEW PYTHON SCRIPT
I would like you to do the following (No need for screenshots, Just do this)
STEP 1- Download the script called
rigol_kg2_3_000
in the attachment
Ensure your scope is on 1.3.2.2
STEP 1 - Delete your priv.pem key from it's location
STEP 2 - Delete the old script from it's location
STEP 3 - Open your command prompt or Powershell and copy the NEW SCRIPT into the location of the directory that the shell opens in
(I'm assuming here that you still have python correctly installed with all the modules)
STEP 4 - Run the -i command like this
python rigol_kg2_3_000 -i 10.1.1.666
replace 10.1.1.666 for your I.P. Address
STEP 5 - Run the -r command
python rigol_kg2_3_000 -r 10.1.1.666
STEP 6 - CONFIRM THAT YOU DON'T HAVE ANY ERRORS
CONFIRM THAT THE priv.pem FILE IS IN THE SAME LOCATION AS THE SCRIPT
CONFIRM THAT YOU GOT 2 PROGRESS BARS INSTEAD OF ONE
STEP 7 - Run the script without the switch
python rigol_kg2_3_000 10.1.1.666
When this completes, it will NOT have activated Options
STEP 8 - SHUTDOWN YOUR SCOPE
STEP 9 - Put the 1.3.2.2 GEL File on USB and as before , go to PRE BOOT and select Upgrade Firmware , to load over 1.3.2.2 again
Take the USB Stick out and Restart your Scope
STEP 10 - Run the -i command like this
STEP 11 - Run the script without the switch
NOW ..... PLEASE TELL ME THAT YOU ARE SUCCESSFULLY ACTIVATED AND LICENCED WITH "FOREVER"
Give that a go.
If it works.... Do not forget
Step 12 - Upgrade to 1.3.3.0
Step 13 - DO YOUR BACKUP from the 1.3.3.0 Backup files
then..
Step 14- Do Self Check - 3 Tests
Step 15 - Do Self Cal
Mate if this works, Also do me a favour, can you please send me a list of WHICH OPTIONS YOU HAD INSTALLED AT THE TIME OF PURCHASE.
