Thank you very much tv84, works great
I had to enter the keys i generated manually as i couldnt get the scope to see the " serialnumber.hlk" file i made . any ideas? what i did wrong
There is info on this thread on *.hlk file formating. Have you tried that?
Hi Everyone,
I recently obtained a HMS-X but unfortunately the tracking gen appears to be limited use and it also does not have the 3Ghz Bandwidth option.
I see reading this thread that some have had success with generating Keys but this is far beyond me.
Is there anybody that would be wiling to help me as although I have contacted R&S I expect they will advise to buy another but as a hobbyist this is totally unrealistic for a nice to have piece of test gear.
Hope I'm not
lol
Danny
Anyone tried this with HMO2024. If so could you please share offsets. Apologies if I overlooked it in this thread.
regards
Hello everyone, great topic thank you.
I would like someone to help me. has RTC 1002 serial number 102546. thanks in advance.
The RTC 1002 is manufactured by Rohde & Schwarz, and they utilize a different licensing scheme than Hameg.
First you will need to provide a memory dump from the firmware, which requires you to open the scope, and connect a HW debugger to the JTAG port.
Once you have dumped the memory, somebody from this forum might be able to assist you.
Also the the R&S serial numbers normally contain two alphanumeric digits at the end, so your serial number should look like 102546-xx
Regards
