RichardK,
I have a list of some little funnies I have noted to date. I am running Win8 and your latest binary. Some are just typos, some are issues that I have had from start, but have listed all as they still seem to be a problem:
1) If full screen is selected the GUI does not display the menu, tool bar and button bar.
Pressing the Esc button returns correctly to smaller display with toolbars and controls panel.
Clicking the small top left hand icon and selecting Restore the display is smaller, but no toolbars or controls are shown,
you have to right click on the display and select Windows Mode to get your toolbar and controls back.
2) Noise issue on base noise with probes grounded still exist:
Settings: Both probes grounded to front ground lug, set to X1, 500uS, both channels 20mV set Zoom to level 19
Ch1 Ch2
20mV Noise No Noise
50mV Noise No Noise
100mV Noise No Noise
200mV Noise spikes Noise spikes
500mV Noise Noise
1V Noise Noise
5V No Noise No Noise
10V No Noise No Noise
3) Autoset is not taking one to best settings option, always to 2.000uS only (I think you are aware of this)
4) Trigger Mode Dropdown box has only one selection. Why have a dropdown then?
5) Corporation is mistyped in About
6) Trigger Sweep One shot freezes waveform display, shows "Stop" and red led flashes on device. Unable to resume if setting is changed back
to Normal or Automatic, but resumes if Factory default is pressed after changing back to Normal or automatic. Pressing Autoset also restarts
the program after freezing.
When placing a cross, vertical or horizontal cursor line without Enabled, the cursors are placed, but needs two clicks on None to remove.
The automatic placing of cursors seem a bit funny with "Enabled".
9) Auto Setup (Toolbar menu) and Auto Settings (Icon) are the two different names for the same thing.
10) Waveform type is called Vector in the toolbar menu and Line in the icon button menu for the same thing.
11) Print preview screen underlines the words when typing in Notes, can the underline be removed?
12) Can colors be changed in Print Preview just for the printout?
13) When loading Factory settings the window asks to confirm and "wan't" is mistyped in this window.(already reported by OP)
Hoping this feedback helps you.
Thanks again for what you are doing!
