Author Topic: Hantek DSO2000 Master Thread (DSO2C10 DSO2C15 DSO2D10 DSO2D15)  (Read 62892 times)
0 Members and 11 Guests are viewing this topic.
Offline Aldo22
Re: Hantek DSO2000 Master Thread (DSO2C10 DSO2C15 DSO2D10 DSO2D15)
« Reply #200 on: March 01, 2026, 09:53:59 am »
A software update has been released.
1.0.3.0.1(250418.00)
Are there any noticeable changes?
Offline manotroll
  • Country: br
« Reply #201 on: March 01, 2026, 11:17:12 am »
They didn't include anything about what changed, I didn't see any difference in usage.
Offline Aldo22
« Reply #202 on: March 01, 2026, 11:50:41 am »
Thank you.
Actually, there has been an even newer version available for some time (dso3kb_20250509).
However, it is not “official.”
https://www.eevblog.com/forum/testgear/hantek-dso2x1x-models-master-thread/msg6099957/#msg6099957
The following users thanked this post: manotroll
Offline manotroll
  • Country: br
« Reply #203 on: March 01, 2026, 01:07:40 pm »
I'll take a look
Offline flez1966
« Reply #204 on: March 01, 2026, 03:40:54 pm »
Just noticed firmware link on the site says 2026-02-26 but when you open the zip the filename is 20250418, bit odd..
I cant install it as my front panel buttons have spent the last 12-18mnth as 'random response generators'...
(well f1-f6+ch1 knob)
Offline manotroll
  • Country: br
« Reply #205 on: March 01, 2026, 05:13:55 pm »
It does this via USB cable, as if it were a recovery process.
Offline DavidAlfaTopic starter
« Reply #206 on: March 02, 2026, 03:44:36 pm »
Seems like the guys over at 4PDA got a newer system software update that isn't here or on Hantek's website yet, dso3kb_20250509. I installed it and seems to be working fine.
I forgot about this! I added both versions to the database  :)
As far as I know, you can't install UPK updates through USB.
« Last Edit: March 02, 2026, 03:46:14 pm by DavidAlfa »
Offline manotroll
  • Country: br
« Reply #207 on: March 02, 2026, 09:59:54 pm »
You will take someone's dump and use it for recovery via USB cable.
Offline manotroll
  • Country: br
« Reply #208 on: March 02, 2026, 10:04:08 pm »
Will this update be released later?
Offline manotroll
  • Country: br
« Reply #209 on: March 04, 2026, 10:42:00 pm »
hantek dso2d50
https://shophantek.com/products/2046879
It seems a 500MHz model has been released; perhaps we'll see software updates for these models again.
Offline Aldo22
« Reply #210 on: March 04, 2026, 11:02:49 pm »
hantek dso2d50
https://www.eevblog.com/forum/testgear/hantek-dso2d20-series/msg6193521/
Offline blackbile
  • Country: hu
« Reply #211 on: March 26, 2026, 07:53:04 am »
I powered on the DSO2C10 (upgraded to 15) yesterday as I need to measure a pwm signal... unfortunately the rotary knobs didn't work.
So I disassembled and found that:
2783195-0
2783199-1
I measured the knobs but I could not find any small resistance as in the youtube video...
After that I cleared the pcb and now all the knobs are working.
Meanwhile I try to update to the latest sw, but the update doesn't work from the front USB port... FAT32 formatted pendrive, any idea?  with a verrry old 256MB pendrive solved the problem.
« Last Edit: March 26, 2026, 08:15:12 am by blackbile »
« Reply #212 on: March 26, 2026, 05:55:57 pm »
The flux is not an issue, check the encoder problem in the FAQ:
»  Rotating encoders unresponsive but buttons working? See [solution 1] and [solution 2]
« Last Edit: March 26, 2026, 06:07:08 pm by DavidAlfa »
Offline vistorik
« Reply #213 on: May 14, 2026, 02:00:08 am »
David, sorry for the question. You developed a dsoflash program based on xfel for Hantek DSO2XXX oscilloscopes. How to use xfel command "xfel spinand read <address> <length> <file>" (what is the <address>?) to read the entire EMMC 5.1 32GB 153FBGA chip YMEC6A2TB1A2C3 (firma YMTC) of "RIGOL DG821 pro" signal generator? The DG821 pro has an Allwinner A40i-H processor and a button for putting it to FEL mode. Thanks a lot.
« Last Edit: May 15, 2026, 01:24:09 pm by vistorik »
« Reply #214 on: May 14, 2026, 11:55:36 am »
I don't remember, but try 0, I think xfel automatically maps the addresss to the spi space.
Offline vistorik
« Reply #215 on: May 15, 2026, 07:19:12 pm »
David, I tried the program xfel on my 2D10 scope with the W25N01GVZEIG memory chip. Reading the memory using the command "xfel spinand read 0x0 <length> dump.bin" is possible. The beginning of the dump.bin is identical to the beginning of the dump, obtained using your program dsoflash. But the xfel reads very slow - 13.6KB/s. It would take about 2h40m to read 128 MB of memory. What can be done to increase the reading speed?
Offline manotroll
  • Country: br
« Reply #216 on: May 15, 2026, 10:53:34 pm »
If it's working, doing it directly via USB with the app is more practical.
Offline vistorik
« Reply #217 on: May 16, 2026, 02:29:26 am »
manotroll, for using xfel, as well as dsoflash of David, the device must be set in FEL mode and connected to a computer's USB-port via a USB cable. The dsoflash v0.36 reads the memory of 2XXX oscilloscopes very quickly, but it does not work with the Rigol DG821 Pro signal generator.
« Reply #218 on: May 16, 2026, 08:18:46 am »
Of course, it's a tool specifically made for this scope. Only.
I might rename it to DSO2D_Flash or something to make it more clear.
All the bits supporting other hardware were removed.
You can still use xfel, though.
Offline vistorik
« Reply #219 on: May 16, 2026, 08:38:30 pm »
David, which software did you use to compile xfel and dsoflash?
« Reply #220 on: Yesterday at 10:43:10 am »
cygwin64.
But... I was checking it, no idea what happened, neither my local or the uploaded sources seem to be synced with the latest binary!
It's missing the lastest changes, where I fixed xfel write32 function crashing by replacing the call with sunxi-tools code.
Only main.c was updated, the rest was completely original, which it's impossible as otherwise I wouldn't have compiled the new version.
Go figure.
Luckly I recalled talking about this here, so it's not totally lost:
https://github.com/xboot/xfel/issues/61#issuecomment-1925295005
But I still had to remember few obscure details I had completely forgotten, like to patch the spi payload so it uses the SDRAM address instead the internal (And small) SRAM.
Edit: Seems it's fixed now. I updated the sources in GDrive.
@vistorik Everything is described in the file README.TXT inside the sources.
## Compilation
Run cygwin64 installer, choose select these packages during the installation wizard:
- libusb1.0-devel
- make
- mingw64-i686-gcc-core
- mingw64-i686-libusb1.0
Compile by running:
> make -sjN (Where N is CPU cores+1, -sj5 for 4 cores, -sj9 for 8 cores...).
« Last Edit: Yesterday at 01:38:22 pm by DavidAlfa »
Offline vistorik
« Reply #221 on: Yesterday at 04:37:43 pm »
Super! You've updated the sources in GDrive, but where is now the dsoflash.exe? Seems you've removed the "bin" folder.
