Author Topic: Help Deciding on new DSO  (Read 2809 times)
Offline BarrySteinTopic starter
« on: January 28, 2020, 02:03:52 am »
I am looking to upgrade my old Owon (PDS5022S) portable DSO. It's old, old enough that some new names have entered into the mix since then.
Asking here for some recommendations. I'll give a few metrics I am after.
1) Portable, so it has a internal batt
2) 100Mhz 2ch
3) 1GS/s DSO with enough memory to store a few 1-2sec captures
4) Has FFT function
5) Budget - $500max
Nice to haves:
1) Be nice if it had remote access software from PC, for controls & display (via wifi or BT or USB, etc), and works good with Windows 10.
2) 100MHz 4ch, or 200MHz 2ch, or 200MHz 4ch
3) 2GS/s DSO
4) Storing waveform captures on removeable memory (USB, SD/MMC, etc)
The names that keep popping up are:
GW Instek
Keysight
Rigol
Siglent
I have not used any of them so I have no idea which ones are most user friendly, which are least problematic, etc etc.
Any suggestions for me to look at?
Online EEVblog
Re: Help Deciding on new DSO
« Reply #1 on: January 28, 2020, 02:22:10 am »
MicSig are the current go-to portable model. Not sure about the models in that price bracket.
THe Siglent SHS806 is under $500
The following users thanked this post: GeorgeOfTheJungle
Offline Berni
  • Country: si
« Reply #2 on: January 28, 2020, 06:16:44 am »
Yep Micsig are pretty much the best bang for buck you can get out of a portable scope.
They last a good while on battery, are small and light for easy carrying while providing the similar feature set and performance you might find in your typical Rigol 1000Z
They also have WiFi for easy connectivity, lets you operate the whole thing from a browser, you can plug in a USB mouse if you don't like the touchscreen.
Offline rf-loop
« Reply #3 on: January 28, 2020, 06:33:26 am »
Quote from: BarryStein
1GSa/s DSO with enough memory to store a few 1-2sec captures
few 1-2sec captures using what sampling speed?
If think sampling speed 1Gsa/s, even 1 second long capture need 1Gsample memory length what is LOT of.
So you need define what is needed sampling speed for these 1-2 second long captures before anyone can answer.
Your old scope is old portable (internal battery) tabletop scope and you did not tell anything you want also change to plain handheld scope. Micsig some models can think they can be both. So I assume you are finding tabletop scope with battery option so it can use also as portable but not only as true handheld. If think functionally scope with battery and what can use nearly like tabletop (touch screen control) and handheld  and IF 1GSa is not at all needed for 1-2s long capture some Micsig models are not really bad in this price range.
Of course there is also some Owon tabletops around inside your budget with battery option what are light year more modern than your ancient PDS5022S. Modern Owon scopes display TFTs quality, perhaps because it is part of well known Lilliput company who knows displays. Performance and features... not worst not best what you can read also as some good some bad.
It is pity most tabletop scopes do not have internal battery option like Owon have. There is still some random demand, even perhaps more if available.
« Last Edit: January 28, 2020, 06:42:56 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum.
Offline tautech
« Reply #4 on: January 28, 2020, 08:07:23 am »
2) 100Mhz 2ch
4) Has FFT function
5) Budget - $500max
Nice to haves:
3) 2GS/s DSO
GW Instek
Keysight
Rigol
Siglent
Welcome to EEVblog.
Almost word for word as you posted on AAC.
My recommendation remains the same.  :)
Avid Rabid Hobbyist
Offline nctnico
« Reply #5 on: January 28, 2020, 12:28:48 pm »
I can vouch for the MicSig. I have a TO1104 myself and it is very versatile scope which can be used as a regular bench oscilloscope as well.
There is a long thread about the TO1000 series:
https://www.eevblog.com/forum/testgear/micsig-tablet-oscilloscope-tbook-mini-to1000/
Since the introduction there have been a few firmware updates which added new features like protocol listing.
« Last Edit: January 28, 2020, 12:33:44 pm by nctnico »
Offline Fungus
« Reply #6 on: January 28, 2020, 12:42:06 pm »
When's your review video?   :popcorn: :popcorn:
« Last Edit: January 28, 2020, 02:11:06 pm by Fungus »
Offline e0ne199
  • Country: id
« Reply #7 on: January 28, 2020, 01:52:47 pm »
keysight is absolutely beyond your price bracket, except if you want to buy the used or refurbished one
anyway why don't you go beyond 200MHz?
« Last Edit: January 28, 2020, 01:55:10 pm by e0ne199 »
« Reply #8 on: January 29, 2020, 04:21:41 pm »
Yes tautech, that was me on AAC.
What about the micsig  STO1152C. It's more of a benchtop then the AT models geared for automotive testing. I only mentioned automotive because I do sometimes drag it into my garage for a test of this or that, or even over to a neighbor who has a race car.
 STO1152C (+batt +decoding) is over $700 though. Is it worth that $700+ price tag? Some of the descriptions on their site is a bit chinglish so it's hard to understand the descriptions there.
