Author Topic: Help with a 121GW Multimeter  (Read 3161 times)
Offline UnexpectedBillTopic starter
« on: October 26, 2020, 03:52:19 am »
I'm in need of some customer service with regard to the EEVBlog 121GW multimeter. I purchased the meter a few months ago through Amazon in the US. Almost everything is fine, but the 1mS PEAK button has to be pushed extremely hard before it will do anything. (I've not had the meter apart to see if I could fix it or determine why this might be a problem.)
Several weeks ago, I sent a message to the warranty claim e-mail address given in the user's manual, but have not heard anything back. I understand that these are unusual times, and perhaps that is why.
I'm not sure what to do at this point. Any help or pointers would be appreciated. Likewise, if this post is misplaced, a gentle correction would certainly be appreciated.
Offline MiroS
Re: Help with a 121GW Multimeter
« Reply #1 on: October 26, 2020, 07:23:49 am »
I think email reading is not affected by covid yet  :-DD
Anyway you may try to report your problem here https://www.eevblog.com/forum/testgear/eevblog-121gw-multimeter-issues/
« Last Edit: October 27, 2020, 08:44:48 am by MiroS »
Offline J-R
« Reply #2 on: October 26, 2020, 08:25:51 am »
The March 2020 manual has this:
If you have a warranty claim, you can contact us at the following email address:
[email protected]
Ph: +61(2)8626 8743
Is that what you tried?
« Reply #3 on: October 26, 2020, 04:10:05 pm »
Sending an e-mail to the address in the March 2020 manual is exactly what I tried. I do not have any reason to believe it would not have gone through...
Offline J-R
« Reply #4 on: October 26, 2020, 06:51:23 pm »
Try sending from a different e-mail address and/or send Dave a PM via the forums?
Offline EEVblog
« Reply #5 on: October 27, 2020, 06:47:52 am »
Likely an easy fix if you open it up and inspect and clean the conductive membrane rubber assembly and contact. Probably some contaminant or object there. An isopropyl should work.
I only recall one other report of something like that, so pretty rare.
The following users thanked this post: UnexpectedBill
« Reply #6 on: October 28, 2020, 03:07:28 am »
I will try cleaning the underlying pad to see if it helps! (I have to admit I find the possible need to do that a little disappointing, but if it works, that's good enough for me.)
« Reply #7 on: October 31, 2020, 06:19:32 pm »
In case anyone happens to be interested, the problem turned out to be a small piece of metal sitting across the underlying contact pads. I'm surprised it never caused "phantom" button presses. With it removed, everything seems to be fine. :-DMM
I suppose it was the excess lead trimmed off from some component or another.
« Last Edit: November 03, 2020, 07:16:58 pm by UnexpectedBill »
The following users thanked this post: EEVblog, AVGresponding
Offline coromonadalix
« Reply #8 on: November 01, 2020, 03:43:05 am »
uh ???
Offline EEVblog
« Reply #9 on: November 01, 2020, 08:57:44 am »
I suppose this was the excess lead trimmed off from some component or another.
That happens unfortunately, seen it also in the BM235. Production debris can be anything in a busy factory.
Offline nuclearcat
  • Country: lb
« Reply #10 on: November 01, 2020, 09:30:23 am »
At least this leg is not hairy  ;D
(sometimes insect parts make similar issues)
Offline EEVblog
« Reply #11 on: November 02, 2020, 03:50:58 am »
Yes, hair is a common find in all sorts of gear.
