Author Topic: Higher Bandwidth Scopes -- With Lasers  (Read 2189 times)
Offline LightlyDopedTopic starter
« on: March 05, 2015, 04:53:43 pm »
Interesting article about the use of lasers in scopes. They can measure frequency components of 125 THz:
http://arstechnica.com/science/2015/03/research-confirms-that-lasers-improve-everything-including-oscilloscopes/
Offline Harrkev
  • ASIC Design Engineer
Re: Higher Bandwidth Scopes -- With Lasers
« Reply #1 on: March 05, 2015, 07:55:42 pm »
This is a sampling scope, not a real-time scope.  Completely different animal.  You also do not want to know how much even a conventional sampling scope costs, even without the lasers.
Seems like cool tech to make an extremely short-duration A/D, though.  The down side is that, when you are going that fast, you probably cannot have too much coax cable length.  The article mentions a "very sharp tip in a vacuum."  I would imagine that this would make for a rather large probe.
Offline electr_peter
  • Country: lt
