I have one of these. Never found a manual. As I understand it, it's an electrophoresis power supply (newer ones are much smaller switching power supplies.
It's certainly enough voltage and current to kill you, so be careful.
The weird things I have been able to discern about this that makes it kinda wonky as a bench supply:
- Current mode isn't a current limit, it seems to be "try to source this much current up to the voltage limit (600 or 1200 volts).
- It kinda goes slowly. On purpose?
- I can't quite figure out program mode.
I'll probably eventually use it for parts: Old as they are, the digital panel meters seem to be good stuff, the pots and knobs are solid, and it has a transformer suitable as a plate supply for a tube-based RF amplifier or modest vacuum tube tesla coil.
