So i got three meters one crappy (8€ from the home depot) a little less crappy (rebrand UNI-T, into Voltcraft VC175), and a not so crappy (Fluke 17B+).
It appears that the Fluke is a little off, but still just within spec (measures 3,497K on a 3,5K resistance) and the UNI-T/Voltcraft seems to be more precise measuring 3,500K as hoped, the last meter is just way off, no use, so lets never speak about that one again.
The resistance is a 0,1% 6 digit decade resistance from
this thread. Set to 3.500Ohm (+0,5Ohm contact resistance).
Well, now i found on the local flea-bay a Fluke 8050A for just 40€, if it works that would be a steal, so I'm considering grabbing it, and checking it against my decade resistance, and if its fine ill calibrate the 17B+ against it, its not very high res. but 4 1/2 digit (20K counts) should be enough to get the 17B+ (4K counts) better than before.
I have access to an Agilent 5 1/2 Digit meter, but i cannot bring my own meter to it, but i can build small test jigs and check them against the calibrated 5 1/2 and bring the jigs home and compare to my own meters. On the way i would probably loose a digit or so in precision from adding the tolerances and loss over time/distance/temperature.
I'm planning to build a battery powered 3V voltage "reference" with a 0,01% TI REF3230, check it against the 5 1/2 and bring it home without turning it off, that should allow me to calibrate the 17B+ with reasonable precision.
So is this doable or have i overlooked anything minor/major that screws up my master plan?
