Could anyone share experience/suggestions how to inject offset voltage in something like 1:5 or 1:10 active probes?
Specifically, if I have a calibrated programmable voltage (-1V...+1V), and I have a probe with 1:10 front end divider, how do I make this offset apply to the front stage (eg. FET) amplifier in a way, that does not depend on device under test impedance, or whether the probe head is connected or not?
One option is to apply the voltage to the bottom end of the divider's low side resistor. But in this case the voltage applied to the amplifier will change with the probe's tip connection.
Some active probes chose the dual-amp architecture, where the DC goes through a low pass DC amplifier, and AC goes through a FET buffer path. In this case, the offset is applied to the DC channel's summing node. But dual-amp architecture requires perfect match of the frequency responses to avoid "bump" at the crossover point.
Any ideas how to do accurate offset injection in a single amp, wideband probe?
