My unit has the waveform storage option (and the additional two channels on the front panel instead of the counter). I'm with you - it's pretty anemic, but it does work and you can make some cursor measurements on a stored waveform. Like most HP gear of that era, they didn't cut corners. I guess that's why it was pretty expensive, too! In addition to the elastomeric connectors which ripen with age (and fail), I've also replaced two leaking electrolytics (at separate times), both of which were right next to the horizontal ASIC. When I got the piece years ago, about half of the front panel light bulbs had failed. I dissected everything and replaced them ALL with red LEDs. There were something like 90 of them. Other than that, the only thing that doesn't work is the flood gun in the CRT. The correct voltages make it to the pins on the CRT, but the CRT is dark. So I'm a bit short of the wonderful light show one can achieve with the 1980B.
