Author Topic: HP / Agilent 34401A VFD to LED Display Conversion  (Read 9671 times)
Offline KungFuJosh
  • TEAS is real.
Re: HP / Agilent 34401A VFD to LED Display Conversion
« Reply #25 on: March 18, 2026, 11:41:05 pm »
"ERR" , "-ERR-" no?
as well as ERROR to ERR0R , if it NOT monospace font
It's a printed screen; they can use whatever font they want. Hopefully, they won't choose Papyrus. ;)
Best Continuity Tester Ever
Online Zucca
  • EE meid in Itali
« Reply #26 on: March 19, 2026, 03:13:44 am »
Matter of personal taste now.
Is it not possible to place a small red led that turns on when the Error signal is active?
I would love to see a little red light that warns me something is wrong, even when I am far away from the device.
Anyway you will sell a lot of those bicolor LED for the legendary 34401A... regardless this "error" discussion.... It is not so important.
The following users thanked this post: dimmog
Offline dimmogTopic starter
    • Hubequip
« Reply #27 on: April 19, 2026, 04:29:51 pm »
The "Error" segment is part of the 10th digit on the display (common cathode). Red LEDs have a lower forward voltage compared to white or ice blue LEDs, and we can't add a separate current-limiting resistor for a single segment. So unfortunately, red is not an option.
Hubequip.net :: test equipment parts and more
www.hubequip.net
Offline coromonadalix
« Reply #28 on: April 19, 2026, 06:05:46 pm »
for zucca   add an i/o port of the mcu to drive an big 10mm red led  loll   you'll see your error status
i would be satisfied with the last shown photo of the display, error status is visible    :-+
Offline BillyO
« Reply #29 on: April 20, 2026, 03:48:10 am »
One could put a little bit of red filter over the "ERROR" annunciator.  That would make it 'eye catching'.
Bill
Offline Zoli
  • Grumpy old men
« Reply #30 on: April 20, 2026, 04:29:31 am »
There's no room for two in series? >:D :-DD
Edit:typo
« Last Edit: April 20, 2026, 05:18:02 am by Zoli »
    • Hubequip
« Reply #31 on: April 20, 2026, 04:13:47 pm »
Edit:typo
= uneven brightness
www.hubequip.net
Online edavid
« Reply #32 on: April 20, 2026, 05:48:00 pm »
There are "PC red" LEDs which have a blue die + phosphor.
(Not that I think you need to bother with that. I don't even think you should have the ERROR label reversed. As you pointed out, it's rarely used.)
Online Zucca
  • EE meid in Itali
« Reply #33 on: April 20, 2026, 05:58:20 pm »
No, I will then trigger this:
Description:
Edwards EWS-V9 Dc Motor Outdoor Warning Siren
Technical Description:
DC Motor Driven Type; 15 HP Power Rating; Cast Aluminum Housing Material; Non Corrosive; 122 dB at 100 ft Sound Intensity; 460/920 Hz Output Frequency; Edwards. Brand
UPC: 78264001049
Part Number: EWS-V9
Manufacturer: EDWARDS SIGNAL
Your Price:  $49,284.54 / ea
Offline Zoli
  • Grumpy old men
« Reply #34 on: April 21, 2026, 06:06:49 am »
Edit:typo
= uneven brightness
It meant to be a joke, so let's carry on: just place the uneven one on the back of the PCB  :-DD :-DD :-DD
Offline Miti
« Reply #35 on: April 22, 2026, 02:14:52 am »
Just curious, why so much space between the 45 degree segments and the vertical and horizontal ones? If you look at the VFD display on 34401 they are much closer. I’m guessing mechanical limitations?
Fear does not stop death, it stops life.
    • Hubequip
« Reply #36 on: June 03, 2026, 04:16:47 am »
In short, yes.
www.hubequip.net
    • Hubequip
« Reply #37 on: June 03, 2026, 04:21:09 am »
Just a quick update: we're now testing the production prototype.
The supplier change set us back a bit, but we're almost there now.
www.hubequip.net
The following users thanked this post: lowimpedance, the Chris
Offline the Chris
« Reply #38 on: June 03, 2026, 04:31:16 am »
Thanks for the update. Looking forward to it.
Strickly speaking, I haven't been unhappy with the brightness of my 34401A, but once my 34410A arrived last year, I could see that the 01A is noticeably dimmer. Now that a 34411A with a nearly-new display joined the two others, I definitively want to treat my 34401A to one of those LED displays.
    • Hubequip
« Reply #39 on: June 03, 2026, 04:41:39 am »
The original Agilent 34401A VFD was quite bright when new. In fact, they added two current limiting resistors in the latest revision of the display board to reduce the brightness. The Chinese clone VFDs currently available on eBay and AliExpress are noticeably dimmer. The brightness of our LED display is somewhere between the original Agilent VFD and Chinese replacement clones.
www.hubequip.net
Online Smile2016
« Reply #40 on: June 03, 2026, 09:32:10 pm »
Great! Agree the red "ERROR" would probably look really cool. I might struggle a bit to squeeze in a small resistor there to make it work though. I also tend to prefer slightly bolder fonts, but that’s just a personal preference.
Any idea what the overall BOM would come out to, & the selling price & availability?
    • Hubequip
« Reply #41 on: June 04, 2026, 04:07:31 am »
Expected availability is in about two weeks and it will be priced at $69.
www.hubequip.net
    • Hubequip
« Reply #42 on: June 04, 2026, 04:13:40 am »
A few photos for you to enjoy  :D
This is the first unit featuring the upgraded dual color LED display, and it's now available on eBay. Sold
« Last Edit: June 11, 2026, 05:49:31 am by dimmog »
www.hubequip.net
    • Hubequip
« Reply #43 on: June 11, 2026, 05:33:12 am »
Preorders are now open! Shipping is expected to start on June 25, 2026.
https://hubequip.net/products/hp-agilent-34401a-vfd-to-led-display-replacement-led-conversion-preorder
www.hubequip.net
The following users thanked this post: edavid, BillyO, the Chris
    • Hubequip
« Reply #44 on: June 18, 2026, 03:50:57 am »
The dual color LED display replacement for the HP / Agilent 34401A is finally ready, and we started shipping orders today!
Hubequip website: https://hubequip.net/products/hp-agilent-34401a-vfd-to-led-display-replacement-led-conversion
eBay: https://www.ebay.com/itm/325714571683
eBay listing for UK buyers: https://www.ebay.com/itm/327219091572
www.hubequip.net
The following users thanked this post: KungFuJosh, symphonystars
    • Hubequip
« Reply #45 on: June 18, 2026, 07:51:01 pm »
I'd like to point out that the new 34401A LED display is a true drop in replacement.
No additional wires need to be soldered to the display board, making the installation process quick and straightforward.
Simply desolder the original VFD display along with its mounting brackets, then solder the new dual color LED display in its place.
www.hubequip.net
Offline willinsau
« Reply #46 on: June 23, 2026, 12:38:32 pm »
Are all firmware revisions compatible with both early and late versions of the 34401A VFD display assembly?
    • Hubequip
« Reply #47 on: June 23, 2026, 02:14:34 pm »
Yes, the LED display is fully compatible with all three display board revisions as well as all firmware versions.
www.hubequip.net
Offline kblue
« Reply #48 on: June 23, 2026, 07:03:22 pm »
Out of curiosity are there any advantages with this conversion? As far as I know the VFD version is available in large quantities.
Best wishes!
    • Hubequip
« Reply #49 on: June 23, 2026, 07:27:53 pm »
Best wishes!
It's up to you VFD or LED. The only thing to consider is that the replacement VFDs on the market are all Chinese clones
and their long-term reliability is a bit of a question mark.
www.hubequip.net
