Author Topic: I want to flip your lid!  (Read 1522 times)
Offline JwallingTopic starter
  • This is work?
« on: November 24, 2017, 10:59:47 pm »
https://www.ebay.com/itm/HP-Hewlett-Packard-Cerjac-OC-12-Circuit-Board-02-2400-2080/152801364447?hash=item2393abc9df:g:~UoAAOSwVqlZ6z0O
I so want to de-cap the massive chip on this board... If it were less than 30 bucks I'd buy it.
« Last Edit: November 24, 2017, 11:03:34 pm by Jwalling »
Jay
System error. Strike any user to continue.
Re: I want to flip your lid!
« Reply #1 on: November 25, 2017, 08:33:33 am »
Standard Hybrid chip there, though it is soldered in upside down so the ceramic case side is a heatsink mount. Inside there will be a white ceramic multilayer substrate, gold traces in multiple layers and silver soldered chips on the ceramic with gold bond wires, along with thick film resistors, diodes, transistors and probably some matched length traces to pass the high speed signals through the glass seals, along with likely some ceramic chip capacitors and some solid tantalum, most likely wet tantalum, decoupling capacitors soldered to the board.
  • This is work?
« Reply #2 on: November 25, 2017, 11:18:00 am »
Oh. I had thought that the chip was socketed...
Jay
« Reply #3 on: November 25, 2017, 02:48:11 pm »
Lid is soldered to the case, so opening will be destructive.
