Author Topic: Identify RF sensor head  (Read 1666 times)
Offline BudTopic starter
« on: December 26, 2015, 03:20:52 am »
Does anyone recognize the RF sensor part pictured in the attached assembly? It is a ceramic part with a input terminal on top that connects to the outer N-type head connector, and two terminals on the bottom that seem to be output terminals that come in contact with the rear assembly , part of which that holds receiving contacts is  made of a fiberglass round.
The sensor head was part of a RF Peak Power Meter made by Republic Electronic, a link with a picture of it:
http://www.exsupplies.com/republic-electronic-ppm101-rf-peak-i3829311/
The device seemed to measure up to 3kW RF peak power.
I wonder if the detector can be reused but not sure if it is operational and how to wire it. The detector element has the following marking: "reic 3015" on the side and "59 W29" on the bottom. It does not have continuity between any terminals, just shows about 30pF capacitance between the bottom terminals.
