Bad news for you, Ir thermometers are based on IR emission, and not all material emits Ir on the same way, The capacity to emit more or less IR of a material is called emissivity, ( this is quite complex and changes with temperature and format ), Unfortunately for you, liquid metals are the worst case scenario for IR thermother to operate, and very few models can do this on a reliable manner , and all cost some k's dont expect to do this with cheap products will not work even with the very expensive ones isn't a easy task. If you don't have a very big budget stay with discartable thermocuples. All low cost pyrometer for this aplication will be a waste of time and money
