In a nutshell, how does this compare to the LB06?
I guess no one that has one of these also has an LB06. Maybe I'll buy both and compare. Who knows, I done dumb shlt before.
I only have the SG-003A (the SG-00
4A has more features, is more accurate, and more expensive), but based on the information available, I’d say these devices differ quite a bit from the LB02/LB06.
Here are a few main differences I’ve noticed:
The LB0x models can’t measure and output at the same time because they only have two ports. The SG-00xA models have four ports.
The LBx models have a basic LCD display, while the SG-00xA have a color display that can also show graphs (attached photo).
LB0x models can only output 0–11 V, while the SG-00xA can output 0–24 V.
The SG-00xA models are calibratable.
The SG-00xA models are programmable (e.g., increase the voltage by 100mV every second).
etc.
As I said, I’m not personally familiar with the LB0x models, but I’ve noticed these differences (without guarantee).
I’m sure the LB0x models also have certain advantages. For example, the LB02 is more accurate than the SG-003A, but SG-004A is also accurate.
The SG-003A is the least expensive of them all.
I think you have to compare the specifications carefully and decide which features are more important to you.
