Author Topic: Is this an ok DMM for home/hobby use?  (Read 4870 times)
Offline ElektronixTopic starter
« on: March 13, 2017, 02:26:32 am »
Hi  :-+ I'm in England & for various reasons have found myself needing a better DMM.
1 of my hobbies is classic arcade video games & lately I've been tinkering with a few Wells Gardner/Zenith 19" K7000 monitors.
I'm looking for a half decent DMM for checking capacitors, resistors, diodes, voltages, continuity etc that gives readings I can trust & £50 is about the budget at the moment.
I have a cheapo XL-830L (think it was about £4) but it's not up to the task surprisingly  ;D
In a shop just up the road from where I live, they have this DMM for £50, most places on-line seem to have it for about £100 so it seems like it might be a bargain.
Greenlee DM-210A
http://www.conrad-electronic.co.uk/ce/en/product/127166/Handheld-multimeter-digital-Greenlee-DM-210A-CAT-II-1000-V-CAT-III-600-V-Display-counts-6000?ref=searchDetail
After doing some research it seems to be exactly the same as a Brymen 252, but the Greenlee has a Backlit LCD. Do you think it's a good buy for £50?
Another one that caught my eye on-line is the OWON B35T from gearbest for £38 it has True RMS and bluetooth etc but I'm not sure I'll need that.
http://www.gearbest.com/multimeters-fitting/pp_402378.html?wid=21
Any input would be much appreciated, as I'm thinking of buying it in the next day or 2.
Re: Is this an ok DMM for home/hobby use?
« Reply #1 on: March 13, 2017, 02:31:02 am »
Welcome to the forum.
Any of those would be OK for a basic DMM that you don't want to stress but the holy grail of info on DMM's is this thread:
https://www.eevblog.com/forum/testgear/hear-kitty-kitty-kitty-nope-not-that-kind-of-cat/
Joe's tested all of those so check out his vids and comments.
Avid Rabid Hobbyist
The following users thanked this post: Elektronix
Offline retiredcaps
« Reply #2 on: March 13, 2017, 02:32:24 am »
Greenlee DM-210A
I have the Greenlee DM200A.  Teardown pics at
http://mrmodemhead.com/blog/gallery/dm200a/
I got it for about $20 USD used.  A great bargain at that price.  I like the large digits.
Brymen make good meters.  Dave's current meter is a Brymen rebranded meter.
« Reply #3 on: March 13, 2017, 03:07:21 am »
Thanks for the welcome tautech, I'll check out that thread for sure, time for a pot of coffee :D
Interesting pics retiredcaps, thanks very much. It looks fairly well made, decent fuses & input protection etc.
I think I'm leaning towards the Greenlee for the build quality and the UL listing & it seems like it will do everything I need.
Apologies for the newbie question but, with your DM-200A, when measuring resistors are you able to touch the probes together and press a button to zero out the display?
On my cheapo meter I'm always having to make a mental note of the probe leads resistance (which seems to change every 10 minutes & fluctuates between 1 & 5 ohms) and then subtract that from the final value, it's a real ball ache.
Offline retiredcaps
« Reply #4 on: March 13, 2017, 03:14:19 am »
Yes, that is what the "REL" button does on the 200A.
If your cheapo meter is always fluctuating between 1 and 5 ohms, either the probes are bad/worn or the input jacks are poorly soldered onto the pcb.  In addition, 1 to 5 ohms with probes shorted is very high.  It should easily be under 1 ohm.
The 200A with probes shorted show a consistent 0.1 ohms.
« Reply #5 on: March 13, 2017, 03:24:07 am »
Great, thanks again RC  :-+
Online EEVblog
« Reply #6 on: March 13, 2017, 03:37:44 am »
Yes, Brymen make good meters, can't go wrong.
Offline Fungus
« Reply #7 on: March 13, 2017, 05:12:38 am »
Fluke 101
(yeah, it doesn't do current but you probably don't measure amps very often and you can use your XL-830L for that)
« Last Edit: March 13, 2017, 05:37:07 am by Fungus »
Offline Fungus
« Reply #8 on: March 13, 2017, 05:31:15 am »
Remember that robustness isn't the only feature in a multimeter.
(Yes, I know Joe tests other features, too...)
But not for 50 bucks.
« Last Edit: March 13, 2017, 05:33:10 am by Fungus »
Offline ProBang2
« Reply #9 on: March 13, 2017, 05:50:25 am »
"But not for 50 bucks."
Ahemm... - look at the first posting:
Greenlee DM-210A
The thread-opener has obviously an offer. Really a bargain. If it is new, then I would take it immediatly.
Without any further hesitation.    :-DMM
