Author Topic: Janky Hakko FX951!  (Read 1254 times)
Offline WmackyTopic starter
Janky Hakko FX951!
« on: July 24, 2021, 03:21:58 pm »
Whats up with this new FX951 I just got. It will not enter sleep mode no matter what I do!! >:(  Did I get a turd?
« Last Edit: July 24, 2021, 03:23:45 pm by Wmacky »
Offline Rhine_Labs
  • Rhine_Labs
    • My Personal Blog
Re: Janky Hakko FX951!
« Reply #1 on: July 24, 2021, 05:16:44 pm »
Real or Fake?
Offline Old Printer
« Reply #2 on: July 25, 2021, 01:22:25 am »
There is an FX951 on Bangood for $94 from China, got to be counterfeit/knock off. Is it one from a source like that?
Offline DaJMasta
    • medpants.com
« Reply #3 on: July 25, 2021, 02:57:31 pm »
It enters sleep mode when the pencil is placed back in the holder, so it's worth checking that.  Make sure you have the holder cable connected, and if you already do, you can probably remove the end that goes into the base unit and do a continuity check on it to verify the switch is actually working.  You can also check the manual for setting sleep functionality, and make sure your temperature is above 300C, as it states it will not sleep if below 300C.
