I picked up a non-working Keithley 2001 today. I've located the service manual and am reviewing repair options. I'm not an EE, but I have an engineering education (Civil Engineering). I've dabbled in electronics as a hobby as a young man, and I have basic solder skills. A repair is not out of my capabilities (I hope - these boards are more complex than I've worked on in the past), but any advise would be greatly appreciated.
I have not tried to power it up, but the owner advised that the power fuse blows on each power-on attempt. I removed the case and found what appears to be leaking electrolytic caps (based on the oily film near them on the power board). I've been searching the forum and have found this to be a common problem with the 2001. Pictures are at the bottom.
Questions:
1) Is there any thing else I should look to replace while I'm inside of the case?
2) Are there specific recommendations for replacement caps?
3) Any suggestions/shortcuts/gotcha's regarding disassembly?
4) Are professional repairs available, and if so can you recommend a shop?
5) What's the add-in board in the rear-accessed slot?
6) I've previously used anhydrous alcohol spray to clean PCBs; is this safe to use on these boards?
7) Any feedback re: the photos?
I would like to get this operating, as it is probably the only chance I'll have to own a Keithley (REALLY good deal on this one).
Thanks,
Beuford
