Author Topic: Rohde & Schwarz CMU200  (Read 170916 times)
Offline Radioman260
Re: Rohde & Schwarz CMU200
« Reply #375 on: July 06, 2025, 11:23:17 pm »
I have successful communication, but my commands are not valid with the CRTU. FETC:AF:SINAD does not work. I've also tried SYST:CMD:LIST and that does not work.
Anyone able to point me to a good command list I can use for the CRTU-RU?
Online KungFuJosh
  • TEAS is real.
« Reply #376 on: July 07, 2025, 02:05:44 am »
Don't limit yourself to that model. I wrote definition files for TestController for the SMIQ and SML series. While doing so, I found some commands in their respective manuals awkward, but found my answers in other series' manuals. R&S doesn't rewrite the book for each model, so you'll likely find what you need in something similar. The SCPI commands for the SML and SMIQ were almost entirely the same. I would bet those files could be easily modified for other R&S sig gens.
The first SINAD reference I found for the FPS is: CALCulate<n>:MARKer<m>:FUNCtion:ADEMod:SINad:RESult<t>?
Anyway, hope that helps.
Thanks,
Josh
Best Continuity Tester Ever
Offline Bicurico
  • Country: pt
  • Broadcast Systems & Transport Stream Analysis
    • VMA-Broadcast
« Reply #377 on: July 07, 2025, 06:54:57 am »
Saw your email, reply here. Check the attachment.
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #378 on: July 07, 2025, 06:58:24 am »
This link is valid for 3 days: https://we.tl/t-GuerpdEWyO
Has the complete Operating manual.
The following users thanked this post: Melt-O-Tronic
Offline _Wim_
« Reply #379 on: July 07, 2025, 08:56:09 am »
Some other docs that might be interesting..
Offline Radioman260
« Reply #380 on: July 07, 2025, 10:51:08 am »
Wim & Bicurico thanks for the attachments. What I'm hoping to do is perform a SINAD test. By enabling the RF generator and then using the AF analyzer. I am not sure it's possible to do. I do not have the AMPS option (I do have the B41) and when I attempted to update the firmware on my digital board from 4.51 to 5.10 it did not go well. I thought maybe I could use python and my GPIB adapter. If any of you more adept in these topics think otherwise please speak up as this is all new to me.
Offline _Wim_
« Reply #381 on: July 07, 2025, 10:57:00 am »
The K29 is a software only option. You can active this yourself, look here: https://www.eevblog.com/forum/testgear/enabling-options-for-rs-test-equipment/25/
So you can add all options starting with a "K".
I have not used the SINAD myself, so cannot give any advice on that topic.
Offline Radioman260
« Reply #382 on: July 07, 2025, 02:09:08 pm »
Wim,
I followed your link to that thread. I did see someone shared a file on a file sharing website where the link is no longer valid.
My problem is as follows and I'm looking for assistance.
1. I have a CRTU-RU with a B41 card, I'd like to be able to perform a SINAD test, but I do not have AMPS. I was getting assistance from someone, and we tried to upgrade from 4.51 to 5.10 and my digital board did not like it...lots of errors. We decided that since the test set is happy at 4.51 to leave it there as I have a working system.
2. It was suggested to use python to make the set do what I want, which is fine, but doing this is the equivalent of drinking form a fire hose, not afraid to do it, but I have a lot to learn. If someone can help here or give some pointers.
3. Can I add AMPs to my set at 4.51? If so can anyone provide the steps for that? It looks like I could maybe download a file and place it in a directory? Where can I find this file? Then I would need some sort of keygen file? I see lots of references, but only old expired links.
Offline _Wim_
« Reply #383 on: July 07, 2025, 03:56:30 pm »
https://rohde.nonexistent.ca/
Follow this link and enter your serial number at the top and select which licences you want (and select CMU200). This should hopefully work for a CRTU also. I checked with the ones I generated for my CMU200, and got exactly the same result with this link.
Serial number has normally the following format: xxxxxx/xxx
Hope this also works for a CRTU!
Not sure if you can add AMPs to 4.51, but if you can enter a licence key for that options, it should be possible.
Offline Radioman260
« Reply #384 on: July 08, 2025, 01:36:02 am »
Wim,
I know where to find my S/N, xxxxxx/xxx but what is the /XXX bit about?
Offline _Wim_
« Reply #385 on: July 08, 2025, 05:59:56 am »
The serial on my cmu200 has a /xxx at the end. But looking online this appears not always be the case. So just enter the serial number in the format it is...
Offline snickers
    • RF Electronics
« Reply #386 on: July 11, 2025, 04:13:37 am »
Yes, I made internal speaker working.
You can see(and hear) it on this video
But remember - not every CMU200 physically have speaker installed.
« Last Edit: January 09, 2026, 07:13:22 pm by snickers »
Offline sparkchaser98
« Reply #387 on: July 17, 2025, 10:05:38 pm »
I'm working on a R&S CMU200 backlight. I'm trying to troubleshoot the screen backlight. I purchased and installed a new bulb and driver, but still no backlight. Since I have no schematics for this thing, I was looking at data sheet for the TDK CXA-L0605-VJL CCFL driver board has an input of 5 volts DC, while output is upwards of 1500-1700 volts. I measured 5vdc on pins 1 and 3, and 2 and 4, per the data sheet. But best I can tell, its putting 5vdc out on CN2-1 and CN2-3 where there should be 1500+ VRMS.  I'm not sure how to test the CCFL bulb short of replacing the driver board. Since I don't have an actual schematic for this driver board, not sure how to proceed short of throwing money at it and buying yet another driver. I bought an "LED Conversion Kit" online, but it came with no driver or instructions, just a strip of LEDs, which have disappeared from my parts box. At the time I tried figuring out how to do that, and the seller directed me to another website where someone installed a similar kit into a different piece of test equipment, but that also did not have sufficient information for me to go by either.
Offline richnormand
« Reply #388 on: July 18, 2025, 07:34:40 pm »
Post #4 here has the info on the inverter board for the LCD display and the thread has info on how to remove the front panel to get access to it.
https://www.eevblog.com/forum/repair/rs-crtu-need-help-removing-the-front-panel/msg1127200/#msg1127200
In my case it was a blown fuse to the lights.
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline Radioman260
« Reply #389 on: September 02, 2025, 04:45:27 pm »
Hoping someone out there may have some information. Also if there is a way I can identify a later generation digital board I could try?
Offline tv84
  • Country: pt
« Reply #390 on: September 02, 2025, 09:03:27 pm »
It doesn't. CRTU uses 30-digits licenses.
Wim,
If you don't see /XXX, use /000.
Offline Bicurico
  • Country: pt
    • VMA-Broadcast
« Reply #391 on: September 03, 2025, 01:05:05 am »
It works just the same for the CRTU in DOS mode, which is the same as the CMU200.
tv84 was referring to the Windows mode, which uses a different licensing method.
The following users thanked this post: tv84
Offline snickers
    • RF Electronics
« Reply #392 on: January 09, 2026, 07:30:50 pm »
Now I'm focused on final testing of my R&S CMU-B11/B12 clone GPSDO timebase.
« Last Edit: January 15, 2026, 12:52:31 pm by snickers »
Offline RBBVNL9
« Reply #393 on: January 09, 2026, 08:49:47 pm »
Looks very nice, GL!
The following users thanked this post: snickers
