Author Topic: Keithley DMM7510 Hidden & Undocumented Features  (Read 709 times)
Richard W. and 15 Guests are viewing this topic.
Offline Mickle T.Topic starter
  • Country: ru
« on: July 05, 2026, 08:05:46 pm »
The Keithley DMM7510, like its little brother, the DMM6500, is a very nice multimeter in every way. Particularly impressive is the flexible programming capabilities of the LUE and the wide range of built-in functions. Those who have delved a little deeper than the Reference Manual know that even more possibilities arise from the numerous undocumented programming interfaces and other hidden features of these devices.
One such hidden feature is the built-in classic game "Breakout," which lets you discover the names of the device's developers (as well as how much the company values ​​them :).
To launch the game, go to Menu->Settings->Password and enter the game name "breakout" as a password. Good luck!
« Last Edit: Today at 04:40:29 am by Mickle T. »
The following users thanked this post: lowimpedance, thm_w, coromonadalix, jjoonathan, Hydron, Martin72, JimKnopf, InvisibleMan, n55_6mt
Offline Martin72
Re: Keithley DMM7510/DMM6500 Hidden Game
« Reply #1 on: July 05, 2026, 08:27:18 pm »
Now I need to know the other hidden features... ;)
The following users thanked this post: KungFuJosh, JimKnopf, rusoaie
Offline thm_w
  • Non-expert
« Reply #2 on: July 09, 2026, 10:55:40 pm »
I don't see where it says how much they value anyone, maybe a dev snuck this in. Cool easter egg though.
If you win the game blocks will reset.
  • Country: ru
« Reply #3 on: Today at 05:09:40 am »
Attached is a far-from-complete list of TSP interface functions and constants—including debugging and system-level ones hidden behind Lua metatables.
Examples:
1. Entering calibration mode using the admin password if the user password has been forgotten:
cal.unlocknorecall("ADMCAL75MM")
2. Dumping calibration constants:
print(ki.cal.getdata())
3. Remotely disconnecting/connecting multimeter inputs:
ki.dmm.connect = 0
ki.dmm.connect = 1
4. Dumping NVRAM:
print(ki.sysinfo.nvmemdump())
5. Changing the interface language without rebooting:
ki.sysinfo.lang = "SCPI"
TSP$ki.sysinfo.lang = "TSP"
The TSP$ prefix allows the following command string to be executed in TSP mode, regardless of the currently selected system interface language.
6. Executing SCPI commands in TSP mode:
TSP$scpi.execute('TRIGger:CONTinuous REST')
7. Determining fan speed:
print(ki.fan.getfantach())
8. Setting a specific fan speed (0–100%):
ki.fan.dutycycle = 40
9. Forcing the device into local mode:
ki.tsplink.golocal()
10. Rebooting the device:
TSP$ki.reboot()
11. Retrieving the error description for a specific code (example: 0x1642):
print(ki.eventlog.geteventinfo( 0x1642 ))
The following users thanked this post: Richard W., TheDefpom, Martin72
Online Richard W.
Re: Keithley DMM7510 Hidden & Undocumented Features
« Reply #4 on: Today at 08:16:10 am »
Thanks  :) I wonder, if some of them work on my 2601A as well...
display.OFF/display.ON would be nice if they work (for lengthy runs, where nobody watches the display. A simple 34401A has this feature...)
also the "fan" functions could be interesting, "gettemp" to see if its already stabilized and the ability to override the speedsettings.
In some cases its switching between two levels in a 5sec interval. Thats quite annoying if you sit right next to it.
Also for times when less accuracy but more power is necessary, one could set the fan to 100% continuously to keep the device cooler.
I already found out some of the math functions, like "math.mod()" for modulo operations and math.ceil(), math.floor() for rounding up and down work.
The following users thanked this post: Mickle T.
Online Hydron
« Reply #5 on: Today at 10:13:24 am »
I'm going to test some of this out on the dmm6500 too, hopefully the similar UI and firmware means the same commands work. Thanks for the work on this!
