In my retirement I joined an open source project who are using SBC's -typically Raspberry Pi's attached to cheap security IP cameras that utilise OpenCV to characterise meteor paths -
https://globalmeteornetwork.org/ - I know little about astronomy however I was intrigued by their novel use of OpenCV to perform this task.
I subsequently ported their ARM based s/w suite to vanilla x86 linux and enhanced it by enabling multiple cameras to be supported on a single host be it a 10y old laptop or more modern kit.
Tangential to this involvement I noticed how a large number of the largely non-tech global participants - they for sure are astro-nerds but know diddly-squat about IT, were reporting weird problems a lot of which were as a result of using cheap sometimes no-brand wall-wart psu's, and one day I idly set up a RPi 4 I had to hand and using a 0.1 ohm shunt I measured the active current consumed and was surprised at how spiky it was - with my DMM6500 it was easy to see the dramatic spikes in power draw - even something as innocuous as from a remote ssh session, issuing an ls on an otherwise idle system.
So I would like to be able to record over a typically ~8hr period the power draw during an overnight capture and the subsequent post-capture process that is known to cause heavy resource utilisation on an RPi - users who have these units running in airtight enclosures frequently report data quality issues due to the RPi getting so hot it triggers the on-chip thermal protection throttling.
So this characterisation of the power profile is what I would like to achieve and due to the unexpectedly spiky nature of the power-draw I want to use sampling in the order of 1k/s so as not to miss likely transient events.
As far as I can tell no such analysis has been undertaken or published, so there is all manner of almost 'folk-lore' surrounding the most suitable minimum psu specs required for stable running.
I appreciate that this perhaps is seen as largely academic exercise in that one could solve the problem just by over-speccing the psu you choose, however that is ignoring the fact that some of these recording stations operate in very remote off-grid locations such as desserts etc and so use solar/battery based power sources, principally because such places offer very low levels of light pollution.
