Author Topic: Keysight's new 34465A (6.5 digit) and 34470A (7.5 digit) bench multimeters  (Read 239759 times)
Offline 0xfede
Re: Keysight's new 34465A (6.5 digit) and 34470A (7.5 digit) bench multimeters
« Reply #575 on: November 22, 2017, 05:35:32 pm »
Thanks again HighVoltage.
I originally wrote this program because BenchVue is not fast enough for me. And also I don't like the fact that along with LXI instruments application comes installed a tons of bloatware, DLL, unknown module, License manager and so on.
While your first request is perfectly doable I've a problem with the other three that needs to be solved differentely.
The graph header is the suggested save name when you export csv and thats exclude ':' as eligible character. The reason for this choice is that I've to make a lot of captures, store and process them on another machine and I don't want to name each file.
For the X axis right now I'm not acquiring the Aperture Time from the instrument so the displayed value is just the sample number. Of course I can find the command to retrieve that.
Let me know what you prefer for time and date.
0xfede
Semel in anno licet insanire.
Offline 0xfede
« Reply #576 on: November 22, 2017, 05:40:11 pm »
0xfede
Your program works perfectly on both of my 34470A but not on the 34465A and not on the 34461A
May be you can extend it to those instruments as well?
That's strange since I developed this program for my 34465A. Do you have an error? Which firmware version is running?
Offline Messtechniker
« Reply #577 on: November 22, 2017, 05:52:29 pm »
Thanks for the hard work.
Works nicely with my 34465A.
However, the screen print is not complete. See pic.
Even so, the saved pic is complete. OK for now.
« Last Edit: November 22, 2017, 05:57:27 pm by Messtechniker »
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter
Offline 0xfede
« Reply #578 on: November 22, 2017, 06:07:17 pm »
Thank you Messtechniker.
The reason for the cropped image is because your pc is configured with the old (pre XP) scheme. I've added zoom-stretch feature to the picture viewer so it should not happen again. I'll release this version when I'll finish a few other fixes.
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
« Reply #579 on: November 22, 2017, 06:16:16 pm »
On my 34461A firmware A.02.14-02.40-02.14-00.49-01-01 I Get the following dialog box:
[Connection error]
"Unknown Device:
 Agilent
 Technologies, 34461A  MY5320xxxx A.02.14-02.40-02.14-00.49-01-01"
I hope this can point you to the right part of your program, so you can resolve this little glitch ;-)
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
Offline 0xfede
« Reply #580 on: November 22, 2017, 06:30:10 pm »
[Connection error]
"Unknown Device:
 Agilent
Johan-Fredrik
Thank you LA7SJA, I'm implementing the solution.
The problem is simply the fact that I'm looking for a Keysight and you have an Agilent  :P
Offline 0xfede
« Reply #581 on: November 22, 2017, 06:38:04 pm »
So I've implemented almost all the fixes and enanchements. I cannot find the SCPI command for getting the Aperture time (I'm tired) and I really appreciate if someone kindly points me in the right direction.
Best,
0xfede
PS: I messed up when changing the attachment, if you still have the Agilent bug please download the archive again.
« Last Edit: November 22, 2017, 06:48:33 pm by 0xfede »
The following users thanked this post: Svgeesus
Offline LA7SJA
  • Country: no
« Reply #582 on: November 22, 2017, 07:20:49 pm »
I can now download any number of empty sample values (read absolute 0), but the error message is gone. Do I need to put the instrument in a different view mode? I have the same reading in 2W, 4W, Volt DC and Volt AC, what am I doing wrong? The number of samples is according to the time since last download.
Johan-Fredrik
Offline 0xfede
« Reply #583 on: November 22, 2017, 07:35:41 pm »
Johan-Fredrik
Nope, the sw should work without any hassle and I'm sure that the problem is something different between 34465A and 34461A. I need the export of a failed download.
Offline HighVoltage
« Reply #584 on: November 22, 2017, 07:44:34 pm »
0xfede
Thanks for the improvements!
It works now on the Keysight 34465A and the Agilent 34461A.
However, I am getting an error "error caused by remote command" when downloading data the first time from the 34461A.
Offline 0xfede
« Reply #585 on: November 22, 2017, 07:53:27 pm »
Thanks HighVoltage, you have spotted LA7SJA problem.
It turns out that 34461A does not accept the FORM:DATA command while both 34465A and 34470A does.
I'll look for a solution and let you know.
Offline LA7SJA
  • Country: no
« Reply #586 on: November 22, 2017, 07:59:43 pm »
I just sent you a link to my export csv file, the file is seemingly correct (Measuring a 5V ref.) but the program only read 0 (zero) even when reading back the export file.
Johan-Fredrik
[file.csv]
+4.99985962E+00
+4.99985788E+00
+4.99985917E+00
+4.99985540E+00
+4.99985345E+00
[EOF]
« Last Edit: November 22, 2017, 08:10:30 pm by LA7SJA »
Offline 0xfede
« Reply #587 on: November 22, 2017, 08:13:40 pm »
Attached the new version with the FORM:DATA removed for the 34461A limitation.
Johan-Fredrik
It's strange, I can open your file and display a graph without problems. If this update doesn't fix the problem we'll continue tomorrow.
Best,
0xfede
Offline LA7SJA
  • Country: no
« Reply #588 on: November 22, 2017, 08:59:24 pm »
If I change the region to Netherland it sort of works but it shows volts 4999... and not +4.999. This smells like C# automagic import number string Voodoo. Sorry if I can't help you any more but you should be able to change region to Norway or Sweden..... and test. There are many undocumented "features" in the C# metodes that uses the Region/Language settings when converting numbers to strings and strings to numbers and even reading .csv files I m used to write my own import, export and conversion rutines.
Johan-Fredrik
« Last Edit: November 22, 2017, 09:09:27 pm by LA7SJA »
Offline HKJ
    • Tests
« Reply #589 on: November 22, 2017, 09:08:29 pm »
Is that the usual problem with decimal separator that is either , or . depending on country. If the program makes CSV files it also has to be aware of the windows delimiter settings that is , or ; depending on country.
Offline 0xfede
« Reply #590 on: November 22, 2017, 09:36:26 pm »
Modified with the culture forced to CultureInfo.CreateSpecificCulture("en-US").
Hope that fix the issue, please let me know.
The following users thanked this post: LA7SJA, Svgeesus
Offline LA7SJA
  • Country: no
« Reply #591 on: November 22, 2017, 09:49:24 pm »
It works, and thank you for this "Modified with the culture forced to CultureInfo.CreateSpecificCulture("en-US")"
 Johan-Fredrik
Offline 0xfede
« Reply #592 on: November 22, 2017, 09:56:15 pm »
 Johan-Fredrik
Glad that it worked and thanks for your alpha testing.
Best,
0xfede
« Reply #593 on: November 23, 2017, 10:52:29 am »
After downloading the data, the trigger mode changes from "Automatic" to "Immediate".
Would it be possible to leave the DMM in the automatic mode so that it continues to collect data?
Offline 0xfede
« Reply #594 on: November 23, 2017, 11:18:02 am »
Anytime the instrument receive the FETCh command (used to retrieve sample memory) it stops and goes in immediate trigger mode.
However if you go in settings and select "Release Instrument after download" it returns in auto mode but it clear the memory.
Best,
0xfede
Offline blackdog
  • Please stop pushing bullshit...
« Reply #595 on: November 23, 2017, 02:17:15 pm »
Hi 0xfede,
Tested your software on one of my 34461A DMM's and it works!  :-DD
Sometimes its crashes and probely it has someting to do with the function "Release instrument after download" half of the time does not work properly.
Also the pictureviewer is not showing the hole pigture, if i save the picture and show it with Irfanview, than its OK.
Thanks for the program, keep op de good work!  :D
Picture is showing my +10V LAB Reference (about +2PPM to High) the 34461A is showing about +15PPM to high
Kind regards,
Blackdog
« Last Edit: November 23, 2017, 02:38:54 pm by blackdog »
Necessity is not an established fact, but an interpretation.
Offline 0xfede
« Reply #596 on: November 23, 2017, 03:41:37 pm »
Hi 0xfede,
Kind regards,
Blackdog
Hi blackdog, may I ask you to send a command via telnet and check if throw an error?
The command is:
SYSTem:LOCal
Thanks,
0xfede
Offline blackdog
« Reply #597 on: November 23, 2017, 05:02:03 pm »
Hi 0xfede,
This command gives a error on the instruments display: SYSTem:LOCal
SYST:LAB "Koffie met Koek" wil give the picture below and the "error" on the display is visible, the SYST:LAB workt normaly, after the error message appeared.
But sometimes i get this eror message and error message 113, Undefined header
It is not clear for me, why there is sometimes a error message on the screen.
I cant put my finger on it.
But wait...
Clicking a few times on the Download Data button gives a error!
Camera screenshot
I hope this helps a little...
Kind regards,
Bram
Offline 0xfede
« Reply #598 on: November 23, 2017, 05:19:18 pm »
Thank you again blackdog.
So this command is also not supported on the 34461A and I can't use it for releasing the instrument from remote mode.
I'll figure out a trick for that. In the meantime do not use the release instrument after download feature.
Best,
0xfede
Offline LA7SJA
  • Country: no
« Reply #599 on: November 23, 2017, 06:27:34 pm »
I regret to inform you that the "release instrument after download" feature works perfect on my
34461A A.02.14-02.40-02.14-00.49-01-01 (latest firmware)
22.11.2017  22:32            43 008 KEYSIGHT DMM plot.exe
28.08.2014  13:56           296 448 ZedGraph.dll
Johan-Fredrik
