Some news:
- "ON" is activated when the output is active. ... "CC/CV": Same in CC mode (CV = 0 volts).
Any idea how much current I may draw without damaging the unit?
Krissy Yang from KORAD Support answered: 0.1 A is ok without damaging the device. I did a review of the parts: There's a separate transformer winding 12V, half-rectifying, 470/25; outputs are MOSFET switched with 2x 10R (not the smallest one) in series. 2K to GND and a diode for reverse polarity protection. Optocouplers on the power board for ON and CC/CV signaling and reverse for the TRIG/OUT input. Well done, KORAD! If you blow up something there, it will be easily replaced.
If not already mentioned above:
- output capacitance 330/50, two "103" (?) caps to Earth Wire. Far too much for me, but usual.
- relay to switch internal/external sense
- ATTENTION: up to 14V output if only one sense line is connected. Some resistors or diodes connecting internal/external sense will help, easy to install on the power board, only the cover has to be removed.
- fake 20..50 mA current if a protection diode is used in the + output to charge batterys (sense+ after diode). Also reduced current in CC mode. No problems if the diode is used in the (-) line.
And no chance to change the color of ON, CV, CV in the display: it's a encapsulated custom LED module, no way to get into, as xKertx mentioned before.
BUT: Besides the mains switch there's a rectangular hole in the front, only covered by the description sticker. You may place some bright LED behind to get a 10x5 mm light field, on the left of the output clamps, no need to make holes, I made a short test. ON and CC/CV outputs will give enough power. If you may live with two separate LEDs (and both lit in CC mode), you only need two LED and two resistors and some cable for a safe solution. I will do this later.
Transformer windings are switched with a (surprisingly) small hysteresis of only 0.1 v, depending on the output voltage (not the real raw DC, which will change with the mains voltage).
1->2 6.9 V; 2->1 6.8 V
2->3 15.4 V; 3->2 15.3 V
3->4 22.3 V; 4>3 22.2 V
Maximum power output 31*5.1 = 158, while consuming 280 W from mains (56%). Unloaded ~14 W, similar to my KA3005P.
Cooler fan is powered from a unregulated supply, thus significant slower under heavy load, and turns up when load is off. Just as my KA3005 does.
Fan has significant lower noise than KA3005, even compared to my silent Welectron edition.
I don't like the voltage/current settings, the KA3005 is better to handle.
Nevertheless: To me, it's the way more useful device compared to the KA3005, for ~ the same money (D model via botland.pl).
I hope I will never blow up my transformer windings fuses, let's see...
