To ping up due some longer ownership too to share.
For Stinger's question answer is
no due this meter uses different chip than example 8008. I tried this multiple times during the years until just recently i got to know fact this chip by rumors the pin is not wired up in silicon level and its not DM0660 its more likely DM1106EN on this models.
I hated the not so trustfully of readings of resistance during the years fighting against it many ways including changing the plugs from split boots from other dmm to solid ones but.. is that the turning knob
can and
will cause
readings go wrong and show whatever readings if it knob's contacts are dirty (wore) or you didnt put it back correctly exactly.
I hate it that is possibility though cleaning and putting back after buying Brymen BL21S2-T4SC Silikon test leads ( for couple of dmm's ) now shows 0
on this one finally maybe first time for years so yeah.. You get what you paid for.
Still love the able keep it on and forget it running and still having battery after modifying the eeprom always staying on and backlight staying on forever too if want but i think i found my deal breaker finally and what made even finally wanting write this message here. Knob.
