We have and use the Hioki IM3536 and Tonghui TH2830, both acquired new awhile back for a project where we had to have known accurate results.
The IM3536 just does everything well, goes from 4Hz to 8MHz, has high DUT current (>100ma, good for low Z) and has a low voltage DC bias built-in. However, the fan sounds like a jet engine....and this is normal!!
The TH2830 is good, does everything well and the fan is quiet. However, it's limited to just displaying 2 parameters, no DC Bias and works from 50Hz to 100KHz. The more expensive TH2832 has built in DC Bias and goes to 300kHz 200kHz.
As mentioned, for low capacitance measurements, higher frequency measurements are preferred, and we use the IM3536 more often.
For external DC Bias we've created a custom fixture adapter which allows much higher applied voltages and successfully measured some PN junctions vs DC Bias in the pF regions. We've also created some simple routines that allow plotting multiple parameters, if you search you'll find some of this.
Best
