I know there are a number of folks here who are not fans of the 3000 series, but it's a lot scope for $2900. Based on a 2014 release, these scopes are not very old either - the "z" series was just released late last year.
I like the idea of pushing sustainability by maintainance. Another very interesting offer:
https://www.ebay.com/itm/LeCroy-Vehicle-Bus-Analyzer-VBA204Xi-204Xi-2GHz-10GS-s-Oscilloscope-Probes/113332193476?hash=item1a632008c4:g:18YAAOSwPTlb03e4
This is a portable Lecroy scope
Yes, when you buy a 10 year old machine you will have to do some maintainance and in that process you will learn in the www what to observe. Not a real problem for an engineer or scientist. Just stay calm and avoid crazy things like motherboard upgrades, option hacks and the like.
Our WR 64Xi is similar to the VBA and i am confident we can keep it running after having spent 2 or 3 days exchanging the touch panel, cleaning the dirt inside, fixing one of the rotary encoders, renewing the clock battery etc. It did have the black handle and stronger fans and i got some explosion views of the mechanics from LeCroy. It's easy to take apart and mount even without those drawings.
LeCroy service and accessories are expensive. But there are enough of those pre-owned machines around to get help elsewhere.
Regards, Dieter
PS:
And yes, a 20K scope should not be portable, because portable scopes keep falling down, independent of which handle they have. Apparently many of those scopes go to after market with one of the rotary controls broken, like our WR 64Xi. Apparently our scope survived the accident without fatal damage. Let's hope the same is true for that VBA on ebay.
To the Topic:QuoteI know there are a number of folks here who are not fans of the 3000 series, but it's a lot scope for $2900. Based on a 2014 release, these scopes are not very old either - the "z" series was just released late last year.
I´m one of them - cause we got since january 2018 a WS3024.
Bought in the hope it´s a lecroy, what couldn´t get wrong….
Yes, it´s lecroy style, hefty look and feel, lecroy-specific probe-connections, works without any problems with our AP011 currentclamp for example.
Or full hardware serial decoding...
Nice big bright screen....BUT:
Awful slow response, it seems that the hardware is a little bit too weak for the lecroy features.
And it freezes at several circumstances, only hard reset will help.
Many firmware updates so far and an end is not in sight.
Against my rigol mso 5074, the WS lost clearly in performance….what a pity.
The 3000Z models are improved versions what the hardware concerns.
You can see it that the power analyzer option is on only avaible for WS3000Z versions.
I wouldn´t recommend the WS3000 series…
To get the circle closed, in that case I´m with Dieter...
Did you run into any problems with the analog inputs?
If you want to spend that kind of money then look somewhere else. The original Wavesurfer 3000 series have an extremely weak CPU under the hood which isn't up to the task at all.
If you want to spend that kind of money then look somewhere else. The original Wavesurfer 3000 series have an extremely weak CPU under the hood which isn't up to the task at all.Wasn't this scope designed in cooperation with Siglent?
If you are into RF and don't need feature like decoding then I'd go for a second hand scope. In your price range you can find really nice ones on Ebay.
The WS3K scopes run WinCE and a simplified version of the Maui software. The CPU is inferior, the hardware specifications are inferior, and the firmware is inferior to any of the full-Windows scopes. The price, however, is in the range of one of those used scopes so you're not even getting better value out of the WS3K...
I would buy a WS3K over a Rigol or Siglent any day of the week but I'd rather have a WR6KA, WSXs, WRXi, or WP7KA than a WS3K. If OneTouch means more to you than performance then by all means, spend your $3k on the WS3K.
