First off, where are you located?
If you go into your user profile and set your country, your nation's flag will display beneath your userID. Makes things a lot easier for everyone, particularly regarding links to products & pricing.
Regarding the cheap Chinese PSU's, I'd advise skipping them if possible as they're not the best performers, or that well made as a general rule (~$300 & lower range). On the other end of the spectrum however, is Rigol, who makes some decent PSU's for the money. But they start at $450 here in the US, so more than 2x your stated budget.
Fortunately, you may be able to do a lot better used (highly dependent on your location). For example, if you live in the US, you can get a used quality linear PSU easily, and very inexpensively as well. Even a triple output is feasible on your budget, and offers the most bang-for-the-buck IME.
Tested Triple Output Supply search on eBay (US site).
An HP 623x series supply would be within budget as well (x = 4, 5, 6, and 7; also multiple output).
HP 6237B for example. Try searching for these by P/N (i.e. "HP 6237"; can usually find more units listed this way).
