Author Topic: Low power measurement test equipment  (Read 4496 times)
Offline Hur HaiderTopic starter
  • Country: pk
« on: August 03, 2015, 11:38:57 am »
I want to measure the power consumption profile of a handheld instrument for predicting the accurate battery runtime of the device. The current consumption varies from few microamperes to an amp. Keysight(formerly Agilent) has a DC power analyzer solution available that seems to have all the features available. See the link below.
http://www.keysight.com/en/pc-1113932/dc-power-analyzer?&cc=PK&lc=eng
This solution is quite expensive costing several thousand dollars.
Is there any low cost solution available costing few hundred dollars that can be used for measuring the power consumption profile. Any help would be greatly appreciated.
Thanks.
« Last Edit: August 04, 2015, 08:02:30 am by Hur Haider »
Offline kripton2035
Re: Low power measurement test equipment
« Reply #1 on: August 03, 2015, 11:58:17 am »
sorry - no answer - just subscribing because I'm interested too !
Offline nugglix
« Reply #2 on: August 03, 2015, 12:13:52 pm »
If I understand correctly you want to log voltage and current for a longer period of time.
I'd suggest a DMM that can measure current and voltage at the same time(aka power)
and has a decent logging capability.
These shouldn't be too expensive and fit well into the "few hundreds of dollars" range.
I just did that with a HMC8012, worked well for me.
Cheers
Edit: spelling
Offline fcb
    • Electron Plus
« Reply #3 on: August 03, 2015, 12:48:10 pm »
+1
  • Country: pk
« Reply #4 on: August 03, 2015, 01:19:28 pm »
HMC8012 seems to have accurate measurement capabilities.
I was looking for a measuring instrument with a built in power supply so that the voltage drop in the leads and that across the current sense resistor can be compensated and that there is no drop at the DUT end. The measurement in this case would be quite accurate as compared to using a separate multimeter and a power supply.
Another point that I was wondering about is that will the multimeter have a high enough sampling rate to capture ~100us pulses of current  drawn by the DUT.
Offline tautech
« Reply #5 on: August 03, 2015, 01:26:34 pm »
Am I correct, you need a Power Analysis solution for the SMPS in your DUT?
Offline tautech
« Reply #6 on: August 03, 2015, 01:57:15 pm »
The Siglent SDS2000 series has a advanced Power analysis option, a good overview is in the User manual, P173 on:
http://siglentamerica.com/USA_website_2014/Documents/UserManual/SDS2000_UserManual_UM01020-E03A.pdf
(9 Mb)
Product overview: http://www.siglentamerica.com/pdxx.aspx?id=25&tid=1&T=2
Additional requirements: Suitable Current probe and De-skew PCB.
http://www.siglentamerica.com/prodcut-fjxx.aspx?fjid=1311&id=25&tid=1&T=2
  • Country: pk
« Reply #7 on: August 03, 2015, 01:58:44 pm »
I need to measure the power consumption profile of battery powered DUT.
  • Country: pk
« Reply #8 on: August 03, 2015, 02:16:35 pm »
The Siglent SDS2000 series seems to be quite useful for SMPS power analysis, but that is not for what I need it.
