I am in the market for a scope that I can use for a number of purposes, from serial bus to VFD output. I am looking at thePicoScope 5244D, but the manual mentions that it is not for mains use.
But shouldn't a quality CAT II 1:100 probe be able deal with this issue, measuring nothing more than 600Vac. Am I missing something here?
Yes, you are missing at least two dozen discussions on that topic on this very forum.
Search for it...
google "site:eevblog.com measuring mains with scope"
Funny, I didn't see one about the note in the Pico manual. ![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif.pagespeed.ce.5xOqKkq0Co.gif)
That is why you have me.
Seriously, do the search. This is already long topic with no answers. It's done to death here, together with all the reasons, and which are good probes etc.
I wrote about it many times, and won't repeat myself. Also many users here feel like that , and don't even want to write explanation why. It's tiresome repeating stuff all the time.
Also you seem to post here because you wanted us to confirm you're right with your opinion, not to have right answer. Don't float Picoscopes. You and Pico might survive it, but not every time, all the time. PC has exposed GND on all connectors, Pico has exposed GND on all BNCs. Most importantly, all BNC on Pico are connected together.
Best scope for that kind of work is one with isolated channels (from scope and each other)
Using High voltage diff probes makes all those problems go magically avay, on all scopes, all the time.
Pico is superb for that work, because of custom probes.
As far as Picoscopes, i love them, have two. They have many possibilities other scopes don't..
All the best,
