Author Topic: Measuring 12 AWG cable for resistance (HELP!!!)  (Read 12290 times)
Offline SharpEarsTopic starter
« on: August 02, 2015, 09:27:56 pm »
I just received a stranded 12 AWG cable from China in the mail. I can't understand why its resistance is so high. The first question you will ask is, "How do you know its resistance is way too high?"
So, here is what I did:
I confirmed that the cable is definitely made of tin plated copper and not Copper Clad Aluminum (CCA) (Tested with a lighter, which melted off the tin to reveal the copper underneath a single strand.)
The cable geometry is 65/30 (65 strands of 30 AWG wire).
The resistance I am measuring is 0.01121 ohms per meter. This is way too high for 12 AWG copper stranded cable with a 65/30 geometry.
The cable diameter is in fact consistent with 12 AWG (2.48 mm diameter for all strands as bundled).
Here is how I measured the resistance of 0.01121 ohms per meter. I double checked this resistance several different ways:
  • I took a 4-wire kelvin measurement
  • I used two HP lab power supplies current reading (1 A)
  • I used a Fluke 8842A to measure the current to confirm (1 A)
  • I used a calibrated HP 3456A to measure voltage to confirm 0.0588 V at 1 A
Bottom line, the cable is 0.01121 ohms per meter, 11.21 ohms per km, 3.41695 ohms per 1000 ft.
Now, let's get to the bottom line:
WTF? The cable's resistance is twice as high as it should be! What could possibly be causing this?
« Last Edit: August 02, 2015, 09:33:52 pm by SharpEars »
Offline georges80
Re: Measuring 12 AWG cable for resistance (HELP!!!)
« Reply #1 on: August 02, 2015, 09:47:19 pm »
How are you 'connecting' your test equipment to each end of the cable?
Unless you have a GOOD crimped lug or soldered the strands together how are you ensuring that each strand is carrying it's equal share of current? Or are you just relying on the strands 'touching' each other?
cheers,
george.
Offline amirm
    • Audio Science Review
« Reply #2 on: August 02, 2015, 09:48:43 pm »
I tested a bunch of 12 gauge wires (see http://www.whatsbestforum.com/showthread.php?14134-When-12-Gauge-Wire-is-not-12-Gauge!) and arrived at similar results on a couple of spools I bought:
And here it is graphically using Belden as the reference:
The Fry's and BestBuy's home brands have similar DCR to what you measured.  Instead of investigating why, I just avoid them :).
« Reply #3 on: August 02, 2015, 10:04:13 pm »
cheers,
george.
I am using an alligator clip at each end of the 5.24 m cable under test. So, I guess I am relying on each strand touching each other in the end, but the alligator clips to come in contact with at least the outer strands of the cable.
Would you recommend perhaps soldering the strands at each side into a single cylinder and then connecting the alligator clips to the soldered ends?
« Last Edit: August 02, 2015, 10:12:43 pm by SharpEars »
« Reply #4 on: August 02, 2015, 10:15:45 pm »
I tested a bunch of 12 gauge wires...
I am getting 3.417 mOhms per foot. From the cables in your table, I happen to own the Monoprice 12 AWG speaker cable, which I have about 95 ft of remaining.
« Last Edit: August 02, 2015, 10:17:28 pm by SharpEars »
Offline georges80
« Reply #5 on: August 02, 2015, 10:28:55 pm »
I wouldn't trust just a clip on each end to make consistent contact across all the strands. Just a bit of oxidation on the plating and you have a measuring issue. A good quality crimped connector would be the a better choice. Soldering the strands at the end to connect them together would be ok.
Consider that each strand carries a part of the current. The resistance of each strand is in parallel with every other strand. But, if you have poor contact from you clip and between strands then you will get inconsistent results.
Then of course there's the variable of out of spec (lies and more lies...) cheap cable as per amirm's measurements (assuming he made GOOD contact to each strand at both ends of the cables under test).
cheers,
george.
« Reply #6 on: August 02, 2015, 10:52:22 pm »
cheers,
george.
Soldering the strands together made no difference. After soldering all 65 strands at each tip of the cable, I am getting exactly the same results, proving that the current was in fact traveling across all of the strands (equally).
On the lies, lies and more lies front. I did make sure that there are in fact 65 strands of gauge 30 (assumed, but not measured) for a typical 12 AWG stranded configuration. I also made sure that the inner diameter (i.e., the diameter of the wires themselves) was 2.48 mm, which is correct. I also made sure that they are in fact copper strands by heating all of them with a lighter. Aluminum typically deforms at high temperatures rather quickly, while copper maintains its shape even when orange hot.
« Last Edit: August 03, 2015, 12:10:56 am by SharpEars »
« Reply #7 on: August 03, 2015, 01:21:20 pm »
Since I have that Monoprice 12 AWG speaker cable your reviewed, I compared a foot of it to the 65/30 tinned copper cable I received from China. The 65/30 measured 33% more resistance than the Monoprice, even though the Monoprice looked much thinner (more like 14 AWG than 12).
I just don't get it! It seems to be composed of real tin plated copper strands. It is the right diameter. It just measures something awful on an ohm meter. There has to be an explanation. One thing I noticed is that the strands are not tightly wound inside the insulator, more like straight than a wound geometry, so perhaps there is not as good contact between individual strands. On the other hand, I soldered the tips for my test to make sure current is passing through all strands, but that did not seem to make any difference in the measurement.
Offline georges80
« Reply #8 on: August 03, 2015, 05:32:21 pm »
Copper composition from company A could be different to that from company B.
Don't assume the copper has the same 'purity'...
cheers,
george.
« Reply #9 on: August 05, 2015, 12:40:32 am »
cheers,
george.
How do you use copper that is so impure that the resistance is twice as much? I think what I purchased isn't tinned copper. It is tinned "some other metal alloy that looks like copper and passes the flame test."
Offline ywara
« Reply #10 on: August 05, 2015, 01:52:12 am »
Copper is expensive. Looking at the weights in amirm's spreadsheet, it's pretty clear what they are skimping on to get such poor resistance.
Offline edavid
« Reply #11 on: August 05, 2015, 02:22:19 am »
Maybe it's copperweld.  Is it magnetic?
« Reply #12 on: August 10, 2015, 06:03:37 pm »
No, it is non-magnetic (i.e., not copper plated steel). This is the first thing I tested.
Offline ElectroIrradiator
  • More analog than digital.
« Reply #13 on: August 10, 2015, 07:59:24 pm »
If the copper contains a large fraction of recycled metal, and subsequently hasn't been through the proper (expensive) electrolysis refining step, then the DC resistance can easily be much higher than properly refined copper.
Offline CatalinaWOW
« Reply #14 on: August 10, 2015, 08:22:01 pm »
Refer to https://www.nde-ed.org/GeneralResources/MaterialProperties/ET/Conductivity_Copper.pdf
It shows more than 10 to 1 variation in resistivity for various alloys and heat treats of copper.
« Reply #15 on: August 10, 2015, 08:50:58 pm »
Wow, I did not know that. It seems that the Chinese are bilking us by using some seriously crappy copper (or an alloy) then.
I am getting 50% conductivity of a proper 12 AWG stranded wire. I wonder what kind of crap they made their wire from.
Lesson learned: Never buy wire/cable from AliBaba or AliExpress!
« Last Edit: August 10, 2015, 08:53:39 pm by SharpEars »
Offline retrolefty
« Reply #16 on: August 11, 2015, 01:42:11 am »
cheers,
george.
 No wonder the audiofools will spend $100s for special low oxygen interconnect, power, and speaker cable.
« Reply #17 on: August 11, 2015, 03:01:23 am »
I just received my 14 AWG cable, which was the polar opposite quality wise.
I have posted a complete review in this thread: I want to praise an Ali Express Cable Seller
Offline CatalinaWOW
« Reply #18 on: August 11, 2015, 04:55:45 pm »
In most applications I wouldn't be too concerned about the copper resistivity.  Battery cables being one of the exceptions.   Even there it might not be appropriate to say the Chinese are "ripping you off".  If you paid the same price for the Chinese cable that you paid for a low resistivity cable, or if you bought based on a resistance spec you could say you were ripped off, but it seems to me that you got what they advertised.
As to audio applications - maybe for some high power systems it makes a discernable difference, but even there I would select an 8 gauge wire of random copper over a 12 gauge one made of gold plated oxygen free copper.  Most audiophools I have dealt with are buying buzzwords more than they are buying performance.  Maybe I should say all audiophools.  The audio purists who make extreme decisions for technically sound reasons are not really audiophools.
« Reply #19 on: August 12, 2015, 04:54:51 pm »
I am using this for power carrying capacity (in a power supply build). I was told 680/0.08 geometry (and got 65/.25) and the resistivity was not quoted but implied based on geometry. So, I was very much ripped off...
Offline CatalinaWOW
« Reply #20 on: August 12, 2015, 10:29:42 pm »
You've added information.  The stranding was different than you were told.  A rip-off.  If they also told you that it conforms to ASTM B33 or some other similar standard then they also ripped you off on resistivity.  I did a quick web search and found a variety of listings for 12 gauge wire.  A surprising number did not even mention the material used in the wire.  Others used generic descriptions like "copper" or "aluminum".  The vast majority did not mention stranding configuration.  A small minority claimed compliance with standards on wire.  While my quick survey is in no way a statistically valid sample, it at least indicates the range of what is out there.  If it isn't nailed down in writing you are vulnerable to the dishonest and also the ignorant.  Those who can honestly say I didn't know there were different copper alloys, or specifications on wire.  The ignorant and stupid far outnumber the dishonest.  Is it a rip off when someone isn't trying to cheat you?
« Reply #21 on: August 13, 2015, 01:55:24 pm »
Definition of dishonest:
I show him a picture showing that the 680/0.08 cable he sold me is 65/.25 (the picture clearly shows all 65 strands, well at least 90-95% of them individually).
He tells me that in China only 680/0.08 cable is made, so it couldn't possibly be. That is the definition of dishonesty, right there.
Then, when I tell him that not only does my picture clearly show 65 strands, if I put 4 of them next to each other the total width equals 1 mm (i.e., they're .25 mm diam. strands, not 0.08 mm). Do you know what his reply is? He asks me, "But in America don't you have different mm?"
At this point, I don't know whether this guy is playing moron or he is a complete (dishonest moron).
I then tell him that 680 in China does not equal 65 in America and proceed to ask him whether he has one hundred fingers on his hands, because maybe in China you have a different number of fingers.
« Last Edit: August 13, 2015, 01:58:59 pm by SharpEars »
Offline johansen
« Reply #22 on: August 14, 2015, 07:11:33 am »
my boss bought some servers and they came with Chinese IEC power cords that measured 10 ohms. yes, you read that correctly.
we disassembled them and found what almost looked like brass wire, and very little of it. so its possible they threw enough zinc or aluminum in the pot to dilute the copper.
Offline TheBay
  • Country: wales
« Reply #23 on: August 14, 2015, 10:34:01 am »
This thread is very interesting! I have a new Naim setup with an Arcam DAC etc.
I have never been a cable whore and bought/made interconnects, speaker cable based on the type of cable, resistance etc. I have never actually measured any of these cables! I just went by the specs and as long as it was electrically compatible on the sheet, I.e. Resistance and Capacitance I used it.
I used to laugh at those buying expensive cables, but I may have to eat my words after reading all this!
i bought a test length 18AWG silicone multistranded quite a few months back. it has the same result as yours. the resistance is about double of what is expected as per the AWG wiki article (0.036ohm/m), but i did get it as stranded, i use it for short interconnects. i also have local left over cable stocks, which are the real deal. especially the canare cables, they really kick ass (but pricey). i think the cheapie china cable stocks have their own cheapie copper alloy formula.
i am still slowly sampling other cable shops from china, :P wish me luck  O0
maybe franky (iloveelectronics) have more info on which shop has the best copper stock?
edit : out of curiosity, i went and did the measurement for the local electrical line stock. its a 7 strand stiffy house wiring @ 2.5mm2. i tried using my expensive hirschmann clips to get a stable reading, but i think maybe im not too experienced at using it with a 6.5digit DMM, in the end i used a DIY copper hook clip and got the resistance at approx 0.0079ohm for about 1m, very close to the AWG wiki table. maybe there is an ISO standard about cable composition and there are grades which certain cables are allowed to have high resistance ?  :-//
« Reply #24 on: August 14, 2015, 12:18:36 pm »
No, continue laughing at them! The only thing you need is a cable made out of decent copper, which is still for cables all the way to 14AWG less than $1 per meter. Cryo cooling it or having it blessed by a minister of Jesus doesn't change its electrical properties one bit.
« Last Edit: August 15, 2015, 02:05:02 pm by SharpEars »
